Throttle Position Sensor Screws for a 89' Corvette?
Old Aug 2, 2021 | 04:33 PM
ChattyMatty's Avatar
ChattyMatty
Default Throttle Position Sensor Screws for a 89' Corvette?
Throttle Position Sensor Screws for an 89' Corvette?
So, I have been searching all over the place for these screws, I bought some on eBay and of course, they didn't fit but was able to get the weird washers that go on the screws which I didn't have does anyone know the size, pitch, etc. and where to buy them? I found these but they are $9. plus $10 shipping and since they are shipping them USPS they are truly making $9 more dollars on the shipping. Any suggestions would really help, Thanks
Tools - Allen Bolt Upgrade Kit For TPS (lceperformance.com)
Old Aug 2, 2021 | 05:17 PM
Kevova's Avatar
Kevova
If you wonder down to a "pick and pull" type salvage yard odds are you can get a bunch of them for a dollar. Probably a 4mm 20 torx 8mm long. GM tech might have a few in his junk drawer. I
Old Aug 2, 2021 | 05:20 PM
ChattyMatty
How can I reach GM Tech? The nearest junkyard is like 2 hours away. Thanks
Old Aug 2, 2021 | 05:26 PM
Kevova's Avatar
Kevova
GM techs work at GM dealerships. It's hard to believe the nearest towing company is 2 hours away. In every town someone is selling parts of broken cars sitting in their yard.
Old Aug 2, 2021 | 05:40 PM
ChattyMatty
There aren't any junkyards in a 2-hour radius that has any corvettes on their lot.
Old Aug 2, 2021 | 05:44 PM
Kevova's Avatar
Kevova
This isn't a corvette only part. Most parts are generic found on multiple years and bodies types. Take the part you need a match it up at the place with a pile of GM wrecks.
Old Aug 2, 2021 | 06:57 PM
84 4+3's Avatar
84 4+3
I think I have 2 from my car in a tool box I can mail you if they're the same as the CFI cars. I'll just stick them in an envelope. They're doing me no good.
Old Aug 3, 2021 | 06:35 AM
ChattyMatty
That would be great, can you email me at matt@iprintonroses.com thanks
Old Aug 3, 2021 | 04:06 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
be sure to tape them to a piece of card board or the sorting machine will rip them out of the envelope. no fun expecting a smallish screw and receiving an envelope with a big hole in it.
Old Aug 3, 2021 | 04:16 PM
84 4+3's Avatar
84 4+3
I have those doubled heavy ones and was planning on wrapping them too. Just need to find them when I have a minute later.
Old Aug 5, 2021 | 10:21 AM
84 4+3's Avatar
84 4+3
@ChattyMatty these look about right?
Old Aug 5, 2021 | 10:38 AM
WVZR-1's Avatar
WVZR-1
If these are thought to be correct one of you need to ID it @84 4+3 before you ship and/or the OP confirms after he receives. Metric specifications diameter - pitch - length. I have thoughts but left it along because I 'CAN NOT' confirm without them in hand. I was amazed that the info wasn't around but it is what it is...
Old Aug 5, 2021 | 11:06 AM
84 4+3's Avatar
84 4+3
I measured the pitch at .75. It's kind of wonky measuring diameter but I get it at 4.2mm so I would presume M4... so its a m4-.75 x 30mm for what I have.
Edit: looking through the McMaster carr book it would appear to be M4.5-.75 what an odd size unless GM had an oddball one custom made.
Old Aug 5, 2021 | 11:28 AM
WVZR-1's Avatar
WVZR-1
I measured the pitch at .75. so its a m4-.75 x 30mm for what I have.
I suspected the M4.5-.75 and the length seems typical for that spec on other GM forums for similar. I believe if the OP confirms fft after arrival you edit your post entirely and just post what it actually is! It isn't actually that ODD!
Old Aug 5, 2021 | 11:40 AM
84 4+3's Avatar
84 4+3
I've just never really seen an M4.5 in the wild is all... or I guess just paid that much attention anyway. Will update once fitment is confirmed. Thank you for supporting my findings.
Old Aug 5, 2021 | 02:20 PM
ctmccloskey's Avatar
ctmccloskey
Hello ChattyMatty!
There is a shop called Contemporary Corvette down in Bristol PA and they have a Junkyard for Corvettes as they break them down and sell the parts. They do have a lot of stuff there!
Contemporary Corvette is only 1 hour and 18 minutes from you in Allentown. They show up at Carlisle for Corvettes @Carlisle and sell their wares, or at least they used to.
It is a good source of used parts if you need them.
Best Wishes with your project!
Old Sep 26, 2021 | 11:05 AM
ChattyMatty
i am interested if you would send them to me, thanks
To Throttle Position Sensor Screws for a 89' Corvette?
