Bottom end engine rebuild.
The reason I bring all three of these issues to the table is because I plan on fixing them all as one big project. Since a rebuilt would require me to disconnect the trans, i might as well rebuild the trans or replace it while I have it out. And since i need to disconnect the driveshaft anyway, i might as well replace the u-joints. Before i get into this further, i want yall to know that ive never done an engine rebuild before or replaced a transmission.
Engine- After having a retired mechanic friend of mine check out the noise, he is certain a bottom end rebuild is necessary because the noise seems to be coming from deep within the engine around the crank. Not to mention, my oil pressure drops very low (can even dip into red for a split second) when oil temp is above 200°F and my idle is at 600rpm. But when my idle is at 700rpm (thanks to a tune chip) my oil pressure is fine. I am running 5w-40 now with same issue. For the bottom end rebuild i want to do it with the engine in the car (if at all possible)
Transmission- like i said, ever since I've had the car, its never liked to upshift and can be very awkward to drive. I could go into greater detail on the intricacies of how I handle driving with this transmission, but i dont think it will help much. Ive done much research on the tv cable and the governor and they are both fine and adjusted correctly. And the newly acquired slipping from 2nd to 3rd only proves im in need of a rebuild or replacement. Ive gotten quotes for both. $600 for a rebuild with a warranty, or $600 for a replacement with a warranty. A warranty is a must for me. Ill be taking out and installing myself
Vibration- i believe it could be my driveshaft u joints causing the vibration. I just recently replaced my half shaft u joints and they were horrible. Plus it couldnt hurt to do cheap maintenance while im there even if it doesn't fix the problem.
Main Questions-
- what engine rebuild kit should i buy for my stock L98
- , will i be able to do a bottom end rebuild without having to lift or remove the engine,
- are there any major obstacles or things i should take into account,
- should i replace or rebuild my transmission,
- What special tools should i buy or rent if any
- Any informational videos you recommend
- Any tips or past experiences
- What u joints should i get from my autozone or oreillys (they usually dont have spicer but i dont care about the brand)
- If i had every day off and only dedicated my time to doing all of this, how long do you think it should take me
To me it all seems like a walk in the park except for the bottom end rebuild. Im a little anxious on that part. Thanks
Main Questions-
To me it all seems like a walk in the park except for the bottom end rebuild. I'm a little anxious on that part. Thanks
How to Check for Bad Main Bearings (itstillruns.com)
TPIs dont turn fast enough to need that. Get some better heads/intake when money allows. Yes youll need a tune but for 200?? PCM for less, Wongs performance can get you an updated chip.
Cube # doesnt sound like a huge difference but believe me the toruqe...its like having a big block. You can get a cam cheap say from Elgin.
Ask questions and be resourceful
Sounds like for now a stock replacement crank rings bearings, a backyard hone is where youre headed
If the trans is out you only got 2 motor mount bolts holding the engine is.
If you were closer Id give you an engine stand, so much easier working on a block. Youll wanna put new freeze plugs in anyways.
Lost one and sold the car over it too much of a pain to do with it in car
Anyhoo...all the bottom end work was done when mechanic friend identified rod knock. Heard the unfamiliar sound but never knew what it was.
It’s only two bolts for the motor. Leave the rad and condenser. Pull the hood. Done deal. Everything else would come off just getting the heads off.
I honed and replaced 8 pistons with the motor in the car. Trans still hooked up. It sucked. Motor was out two months later to do it right.
