Lumbar bladder Fix?
Old Dec 19, 2002 | 01:28 AM
TIMSPEED's Avatar
TIMSPEED
Default Lumbar bladder Fix?
Anyone have a write-up of how to fix the lumbar bladders in my 87 coupe with the sport seats option?
TIA! :cheers:
Old Dec 19, 2002 | 08:18 AM
don hall's Avatar
don hall
Default Re: Lumbar bladder Fix? (TIMSPEED)
Are bladders leaking, or is the pump faulty? If you have a faulty pump, there are two TECH TIPS in the C4 section.
[Modified by Oldman, 5:20 AM 12/19/2002]
Old Dec 19, 2002 | 12:37 PM
Red Dwarf's Avatar
Red Dwarf
This shud give you some ideas.
http://www.vettenet.org/lumbar.html :steering:
Old Dec 20, 2002 | 09:16 AM
dbelnap's Avatar
dbelnap
I fixed the pump gasket using the tech tip by replacing with a piece of rubberglove and it works fine now.
Old Dec 21, 2002 | 02:13 PM
Juliet's Avatar
Juliet
Default Re: Lumbar bladder Fix? (dbelnap)
I did the rubber glove fix - it only held up for a few months and failed again. :( Maybe the rubber gloves weren't high enough quality? :confused: There was a website a long time ago which had the source for the replacement rubber piece. I can't seem to find it anymore. Does anyone know? Next time I take the seat bottom out I'm going to try the fix with the real part and see if that holds up better - if I can figure out who I need to order the part from that is. :lol:
Old Dec 21, 2002 | 03:58 PM
don hall's Avatar
don hall
Default Re: Lumbar bladder Fix? (Juliet)
Juliet, here is a TECH TIP that uses an old inner tube instead of a rubber glove. The inner tube is much thicker and is much more efficient than the original diaphragm. If you are not interested, I can do a little research and provide a source for a replacement kit (about $35).
https://www.corvetteforum.com/techti...=181&TopicID=2
To Lumbar bladder Fix?
