How to add front brake ducting to C4 corvette?
I've looked and everywhere I look no one has stock for an air duct assembly for a 95 Corvette. I'm assuming I will need to custom build it.
How has anyone done this and what all will I need? Thanks.
Pro Mechanic
You'll have to custom build it.
In the past there was a kit with front air dam vents, the hose was plastic though which would melt. I also remember quantum spindle ducts but they didn't have a full shield around by the ball joint. I've had ducts a long time and it's tough by the a arm to the rotor for the hose to stay undamaged or made into an oval for tire clearance. Custom naca ducts in the nose under the headlights work and there are more options like brake light area or headlight area.
