Oil Cooler install
Old Aug 21, 2021 | 06:16 PM
jseremba's Avatar
jseremba
Default Oil Cooler install
Hi everyone, I am installing the Hayden oil cooler in my 89 Corvette. This car has two fans. I was going to put the cooler in front of the condenser and radiator. But, the AC fan is too tight. I am thinking of putting it behind the radiator. Has anyone found a way to put it in front of the condenser?
Thank you
Old Aug 21, 2021 | 07:42 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
that small fan in front of the radiator is a b4p radiator boost fan, a pusher fan, and it is part of the z51 suspension package. it was also on my 89 6-speed with the fx3 and z51 suspension package. check your spid under the console lid. what i did on mine was to find a later year radiator support bar and zip tie the cooler to it. it will be in the mostly horizontal position. when you run your lines, be sure to route them away from the headers.
Old Aug 21, 2021 | 07:49 PM
jseremba's Avatar
jseremba
Great idea. Thank you
To Oil Cooler install
