Like title says. I've gotten so many versions over the years...wondering what the forum members recommend? Oil viscosity? Brand? Time factors? Distance? Load? :chevy
the break-in procedure varies from builder to builder, and you should ask one of the local builders for his procedure. This is just one i heard:
put in a thicker oil, like 20w50 dino
cam break-in is usually 15min at 2000rpm, some builders will immediately change the oil
500mi, change
another 500mi and change to your regular oil
Use the oil (dino) weight spec'd for the engine, nothing heavier, you don't want to starve anything for oil on the first start, even if primed before hand.
Roller cams don't need a break in, but I still run for 15-20 minutes at 2000 rpm.
Change the oil and filter. Change oil and filter every 500 miles, still using dino for 2000 miles. After 2000 switch to Mobil 1.
I take it real easy the first 500 miles and don't crazy for the first 2000. Yeah this is conservative, but nothing is better than a slow break in.
5-30 dino Drain after the first day, 5-30 dyno drain after 500 miles 5-30 dino 3000 miles then Mobil one after that. You will get several answers. mine has not used a drop after 4k miles
