no oil temperature
Old Aug 29, 2021 | 07:18 PM
jseremba's Avatar
jseremba
Default no oil temperature
Hi Everybody,
I have the oil cooler on my 89 6 spd connected using steel braided lines, NO LEAKS, Yippie!!! But, I also have no oil temperature reading. I checked the wire it is not crimped. Any ideas.
Thank you
Old Aug 29, 2021 | 10:55 PM
jv9999's Avatar
jv9999
If you short the sensor wire to ground it should go to the lowest reading. If you unplug it, it should got to the max reading. If it does that, then you likely have a bad sender.
Old Aug 30, 2021 | 07:23 AM
jseremba's Avatar
jseremba
Just seem coincidental that I put the oil cooler on and I loose the temperature reading. I am wondering if the spacer for the oil cooler does not block the passage way to the oil temperature sensor. I am thinking of moving the sensor to up where the oil pressure sensor is. Putting a Tee. I will disconnect it and see. Thank you
To no oil temperature
