Clunk Shift, eek?
Old Sep 9, 2021 | 05:08 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Default Clunk Shift, eek?
Great.
Twice in the last two days (or so), have had a problem when shifting with heavy foot.
'87, stock, auto tranny, Dana36.
I can't say for sure which gear, I do know it was around 50mph, again heavy foot. Anyway, during the shift, big CLUNK happens, really bad this last one. My ears, which I can't trust due to hearing impairment, think it was from the rear driver side.
I lifted Her today and checked, ujoints look good on half shafts and center. Only concern is moving the rear tire does take about an inch or two each way before hitting the stopping point. I can tell it's at the tranny, not the center ujoint.
I'm thinking tranny is the issue, am I wrong? It has been a poor shifter from 1st->2nd since I bought it, not terrible, just hard. 2->3,3->4, quiet.
Yes, I've played with the TV many times.
Old Sep 9, 2021 | 09:52 PM
KMS88Cal#16's Avatar
KMS88Cal#16
Default Clunk
Are your c-beam bolts tight at the transmission? My auto Vert clunked recently when I had to back out of driveway quickly because of traffic. When I put it in gear-and stepped on it it clunked. My c- beam to the transmission bolts needed to be tightened. Kevin
Old Sep 9, 2021 | 10:49 PM
kael's Avatar
kael
Yes, it's nice and tight. No CLUNK problem noted except that on-it-on-it shift. 1->2 is fine during that, can't recall if the problem was 2->3 (50mph in 2?) or 3->4.
I was a ways from home, drove it the rest of the way with no issues other than my brain racing (What was that? What was that?! Was that anything?!?!?).
Old Sep 17, 2021 | 04:05 PM
kael's Avatar
kael
FOLLOWUP:
Checked the tranny fluid how again, still showed fine. I didn't believe it after trying my cold method. Months ago I noted the correct level the correct way, for my Lady, and then re-checked cold and wrote it down.
Added half a quart to get it back to my cold level. Made several runs to try to repeat the clunk, including whomping on some onramps. No repeat. *sigh*
Well, will start saving pennies for when rebuild or new tranny time shows up.
Old Sep 17, 2021 | 09:43 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Clunk
You said you moved the rear tire an inch or two?
i would start looking at that rear end before it goes out completely.
Old Sep 17, 2021 | 11:22 PM
kael's Avatar
kael
I lowered the rear end an inch last winter.
And yes, first thing I did after the clunk was jack Her up and take a close look at the rear suspension, diff, center shaft and tranny coupling. Best I got was the tranny output is wearing, little extra slack.
To Clunk Shift, eek?
