Smog pump
Old Sep 13, 2021 | 11:42 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default Smog pump
The smog pump in my 85 started making a lot of noise. Since putting on headers it is no longer really being used it is there to pass the visual inspection. I was going to look through the wrecking yards for another pump. What other cars used this pump?
Old Sep 13, 2021 | 08:57 PM
rrt898's Avatar
rrt898
I just gutted mine and left it in the original position.
Old Sep 13, 2021 | 10:07 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Pump
That pump is corvette only because of the mounting and the inlet/outlet locations.
There is a kit to get rid of the pump.
if you are handy, you can make your own kit. Check mid america and zips corvette, ecklers for pics.
use a pulley from a 2001 tahoe idler bracket. Use aluminum 1/2” thick and 1” wide, buy 2 ft.
also aluminum 1” dowel cut to the right length. Drill and tap for bolts.
also thick wall alum tube for spacers. You can also use steel
To Smog pump
