MT2500 scanner ???
Can this scanner change settings in my ecu? I want to change the fan settings and do away with the EGR. Would I have to have a new chip burned. If this scanner can't do that, I don't need it.
The car runs very well now, but being 33 years old, I want to install new injectors and just clean up the engine some and the First intake looks good.
I have read posts about the APU1, but I am happy with the performance of the car as-is, but want to make a couple changes and can't see spending $300+ to change only a couple settings.
This might be clear as mud, but thought I would ask.
The MT2500 is a scanner not a tuner so no.it can't alter programming.
What Kevova told you is correct.
I bought a SNAP ON MT2500 and it came with a boatload of cartridges. I bought it from the "For Sale" section of the C4's. The fellow Corvette Forum member sold it to me and I am very happy with what it does and can do. It is 1980's High technology and a bit outdated. Mine works with an OBD2 adapter as well as the OBD1 and shows me the details going on in my newer OBD2 engines. I have cartridges for many Asian Cars as well as the American cars as well. There is a Cartridge I am seeking that diagnoses and troubleshoots problems with the early Bosch ABS systems. I have heard it helps when you are flushing the brake fluid as well on the early ABS systems.
I have since purchased a set of OBD1 Cables and Bluetooth adapter for the systems from 1320 Electronics and am looking forward to learning how to use it. One way or another I will see what is happening inside the engine!
-- Joe
Before my Tech 1 I had an MT2500. I liked it. It gave me all of the info I needed to support my car. Honestly, I do prefer the Tech 1.
