Tires
Old Sep 14, 2021 | 04:32 PM
North Corvette's Avatar
North Corvette
Cruising
Default Tires
Will I be able without any problems use 255-35- 18 front & 275-35-18 read on 94 c4
Old Sep 14, 2021 | 07:05 PM
slammin's Avatar
slammin
Tirerack.com is your friend. They have tons of info and ratings on most tires. Check out their site. You can find tires by size, vehicle or manufacturer. You will find that most tire big box stores, Sams' Club and costco will match tire rack's prices.Happy shopping.
Old Sep 15, 2021 | 09:02 AM
MatthewMiller's Avatar
MatthewMiller
Those 255/35s up front will be a little too short at only 25" diameter. The 275/35 rear size you picked is perfect. I'm assuming you have the "staggered" sawblades with 17x8.5" wheels up front? If so, you should stick with that rear size but go with 245/40/17 front tires. They will be a good width for the 8.5" wheels and they will match the 25.6" diameter of the rear 275/35s. And there are lots of tire choices in that combination of sizes.
To Tires
