loud clicking or cracking noise upon initial acceleration.........
Old Dec 21, 2002 | 02:32 PM
Wheelman's Avatar
Wheelman
Default loud clicking or cracking noise upon initial acceleration.........
My car seems to have developed another problem......... Whenever i first put it in drive or reverse for that matter, as soon as i press the accelerator i hear a loud clacking sounds like something shifting positions. It then goes away until i stop again and start from another light. Any idea what this could be??? Thanks
Old Dec 21, 2002 | 03:45 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: loud clicking or cracking noise upon initial acceleration......... (Wheelman)
Two thing come to mind,
1 check the motor mounts
2 check the trans mounts
Old Dec 21, 2002 | 03:53 PM
hngacurv's Avatar
hngacurv
Default Re: loud clicking or cracking noise upon initial acceleration......... (grapeknutz)
Could also be a cracked flywheel.
Old Dec 21, 2002 | 10:19 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: loud clicking or cracking noise upon initial acceleration......... (castivers)
Mine used to do that too, but then suddenly quite.......
Whoever suggested the motor mounts might be on to something, but it sounded like it was coming from the rear of the car......
But when I took my engine out last month, the passengers engine mount was ony held on with 1 bolt, to which I could turn by hand! :eek: :D
Old Dec 21, 2002 | 10:37 PM
vader86's Avatar
vader86
Default Re: loud clicking or cracking noise upon initial acceleration......... (ski_dwn_it)
Sometimes when you hear a clicking sound that seems to come from the rear, it indicates worn U-joints.
Old Dec 22, 2002 | 06:50 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: loud clicking or cracking noise upon initial acceleration......... (vader86)
Sounds like a bad U-joint. If its not the U-joint, check the wheel bearing. If the bearing is toasted, the rotor sits a little cockeyed and will make a snapping or creaking sound as the pads move off the rotor at a slight angle.
Old Dec 22, 2002 | 07:56 PM
ittlfly's Avatar
ittlfly
Default Re: loud clicking or cracking noise upon initial acceleration......... (Fastguy)
Check the 4 bolts on the C-beam. Be sure they are torqued to specs.
Old Dec 26, 2002 | 03:15 PM
john738's Avatar
john738
6th Gear
I had the exact same type of noise coming from mine (from the left rear side), started about 3 weeks ago. Turned out to be a bad Ujoint on the drive axle.
Old Dec 26, 2002 | 03:49 PM
NavyVet's Avatar
NavyVet
Default Re: loud clicking or cracking noise upon initial acceleration......... (john738)
Everything above. One more that worked on mine - put a little bit of anti-seize on the splines of the stub axles.
Old Dec 26, 2002 | 05:55 PM
vetracer's Avatar
vetracer
Default Re: loud clicking or cracking noise upon initial acceleration......... (NavyVet)
:iagree:
It sounds unlikely, but putting anti-seize on the axle splines can fix the problem you are describing. I replaced wheel bearings, U-joints, checked everything but the noise persisted. I even removed the brake components to eliminate that as a source, because the noise sounds as if it is coming from right behind the face of the wheel. I finally tried the anti-sieze, and it worked. Made a believer out of me!
[Modified by vetracer, 10:56 PM 12/26/2002]
Old Dec 26, 2002 | 08:16 PM
emoshn's Avatar
emoshn
ski down it...love your logo.
Old Dec 27, 2002 | 11:10 AM
dizwiz24's Avatar
dizwiz24
I agree with NavyVet. I had this same problem...a 'click' from the rear when I would go to accelerate. First guess I would have thought a U-joint.
Turned out the wheel hubs needed reoved, rust cleaned out of the spline shafts, and anti-seize applied to the spline shafts. I didn't believe it would work, but it did.
Old Dec 29, 2002 | 02:14 AM
Wheelman's Avatar
Wheelman
You mean as i am slowing to a stop and letting the brakes off when leaving from a stop?? My car does make that kinda sound and i have been trying to find out what it was.
To loud clicking or cracking noise upon initial acceleration.........
