using 350 damper on a 383 ???
Old Dec 21, 2002 | 02:43 PM
BLUE ONE's Avatar
BLUE ONE
Default using 350 damper on a 383 ???
I seem to remember seeing a post about using an aftermarket 350 cu in fluid damper on a 383 with success to fit a 383 in a C4 frame without having to do any mods :confused: but i cannot find a link.
Has anyone got any info about this, i have been offered a zz4 based 383 short motor but it is externally balanced so as i do not intend to do anything with my frame and i don't want to use the bigger damper i would have to get it internally balanced if this is not possible. why ?? because i don't want anyone to know its a 383 ;)
:cheers:
Old Dec 21, 2002 | 02:58 PM
gtsyellow's Avatar
gtsyellow
Default Re: using 350 damper on a 383 ??? (BLUE ONE)
my friend rich straped a street damper on a zz4 with great success. the 6&3/4" will bolt right on.
lingenfelter actually uses stock GM 6-3/4" dampers on it's 383's, however those engines are internally balanced and assembled very well.
Old Dec 21, 2002 | 03:42 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
If you have the money any thing is possible, but why fight it! I would go with the externally balenced ( 400) damper And dont let them look under the hood! :smash:
Old Dec 21, 2002 | 04:57 PM
Phobos84's Avatar
Phobos84
Sorry but you can't use a 350 dampner on an externaly ballenced engine. You will need a dampner for a 400ci. as far as being able to see the difference the weight is inbetween the engine and tranny. You couldn't see it anyway. Summit racing has a great deal on a 400 dampner that is almost the same size as a 350 dampner. As far as fitting if a 350 can be bolted into a car then a 383 can without any cutting.
Hope this helps
Old Jan 3, 2003 | 10:16 AM
Togo's Avatar
Togo
Default Re: using 350 damper on a 383 ??? (gtsyellow)
so with my internally balanced 383, i can run the damper i have on my car right now? (it's the stock 350 damper) :confused:
Old Jan 3, 2003 | 02:03 PM
Phobos84's Avatar
Phobos84
Default Re: using 350 damper on a 383 ??? (85_togo)
How are you building a internaly ballenced 383? Is it an LT1? I don't know a lot about LT1s but with anything else I can tell you that a 383 crank is externaly ballanced and you will need a dampner for a 400 cid.
Old Jan 3, 2003 | 03:14 PM
gtsyellow's Avatar
gtsyellow
Default Re: using 350 damper on a 383 ??? (Phobos84)
you can easily make a internal balance 383
check out scat's 9000 series 383 shafts, many of these are made to be internal balance & use a 1pc rear with 350 damper
http://www.scatcrankshafts.com/serie...tcranks02.html
a new gm damper is under $60, don't be cheap, buy a new one. you know your going to spend thousands on the engine, $60 won't kill ya :thumbs:
Old Jan 3, 2003 | 03:56 PM
Togo's Avatar
Togo
a good machine shop can internally balance for you....my understanding is that they take the assembly, assemble it and check for out of "roundness" of the rotation.....then they chunk off parts of the crank to fix that!
Old Jan 3, 2003 | 04:32 PM
MrJay's Avatar
MrJay
Most all 383 internaly balanced cranks are for 6 inc rods because the counter weights have to weigh more then a crank that is externaly balanced you can get a 3.75 crank for a 5.7 rods balanced to be internaly balanced but you have to put a lot of mallory in the counter weights and that will cost you, it will cost you $250-$400 to have it done.
Jay
[Modified by MrJay, 4:23 PM 1/3/2003]
Old Jan 3, 2003 | 05:04 PM
Phobos84's Avatar
Phobos84
Default Re: using 350 damper on a 383 ??? (MrJay)
I guess you learn something new everyday. I have never heard of that before. But my question is why? By the sounds of it the internal ballance 383 would cost a lot more and would not give any benifit over external except you get to use a 350 dampner, and like you said they are only $60.
To using 350 damper on a 383 ???
