C4 Problem
Old Sep 22, 2021 | 06:34 PM
laterdude-1's Avatar
laterdude-1
7th Gear
Default C4 Problem
Was wondering if anybody may have an answer for an issue I have with my 1992 base coupe.This doesn't occur on 55 mph or less. It seems like between 55 -75 it may happen then go away. I will be driving and a sound starts to gets louder The car seems to shake a little too. Then it just goes away and may not happen again till another time out. Saturday went 34 miles one way no problem Parked the car at a show for 5 hours in the sun. Coming back home it happened 2 times then went away. Any ideas anyone.Thanks Doug
Old Sep 22, 2021 | 06:36 PM
Moving this to C4 Tech.
Old Sep 22, 2021 | 07:50 PM
arbee's Avatar
arbee
The next time it does that, slightly step on the brake to see if that stops the sound and shaking. If there is no change, try putting the gear selector in D3 instead of OD. This would only apply if your car is an automatic. You do not state that information.
Old Sep 23, 2021 | 06:08 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Could be a bad belt in a tire. Had the exact same thing happen to me (on a different type of car). The first time it happened it sounded like a helicopter driving down the highway. Had to hit the exact temperature to have it happen.
Old Sep 23, 2021 | 10:20 AM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
I tend to agree with Dave. What are the dates stamped on your sidewalls?
Old Sep 23, 2021 | 10:45 AM
vader86's Avatar
vader86
need more description of what is happening.
Old Sep 23, 2021 | 03:34 PM
novaks47's Avatar
novaks47
What type of noise? Grinding, banging, clunking, groaning, clicking?
Old Sep 23, 2021 | 04:29 PM
laterdude-1
7th Gear
It's a loud helicopter sound then goes away in a bit.
Old Sep 24, 2021 | 11:02 AM
novaks47's Avatar
novaks47
I suspect it's a tire issue as drcook described.
To C4 Problem
