Overheating
Old Oct 5, 2021 | 04:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nope, not your doing at all. You got some good options to pursue from this thread.
Old Oct 5, 2021 | 04:52 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Originally Posted by Jowens7896
I wasn't trying to stir up crap with my post was just looking for suggestions.
Well you did, Jowens. You stirred crap up. You're a sht stirrer, Jowens. I tell ya. Some people...
No, I'm just kidding. Heh heh.
I always find the best discussions are the ones that ultimately tend to expand into more intricate factors when folks are supporting their theories. I learn more that way, just by reading through them. I say theories for lack of a better word.
Anyway. All I'll add here is that my 1990/L98 holds exactly 17.8 quarts of coolant after the knock sensors are removed to completely drain and flush the coolant system. It has a stock radiator but I also removed the oil cooler completely and did a throttle body bypass. So now it holds around 17.25 quarts of coolant when filled from a completely empty system.
When I fill it I remove the thermostat and fill it directly into the block. Then I finish it off by filling the radiator the rest of the way through the return hose. Then I top it off at the reservoir. Then I fill the overflow tank to the cold line. Then top it off again at the reservoir after a good drive up to temps.
As was mentioned, the radiator cap is a cheap replacement, and often the problem. Mine uses a 17lb closed system cap.
Also a good idea to check the neck of your coolant fill reservoir for any cracks. Also a good idea to check the coolant fill reservior itself for leaks. You probably won't be able to actually see a leak there since it happens when the coolant comes up to temperature.
A pressure check is usually where I'd personally start investigating.
