Wideband O2 Sensor ?
Old Dec 22, 2002 | 10:52 AM
lead_foot's Avatar
lead_foot
Default Wideband O2 Sensor ?
When I had my car dynoed I went for the wideband O2 sensor option ($15). Thought it would be nice to see the mixture at WOT.
I had never seen this used before so I don't know what the correct procedure should be. The guys at the shop merely clipped the sensor to one of the tail pipes. Since the gases have already gone through the cats is this method going to provide an accurate reading???? This setup indicated I was running a little rich. So I dropped fuel pressure about a pound.
Any thoughts would be appreciated. I don't want to be making changes based on bogus data. :)
Old Dec 22, 2002 | 11:36 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Wideband O2 Sensor ? (lead_foot)
I think it would still give a pretty good reading....but it would be better without the cats... :cheers:
Old Dec 22, 2002 | 11:37 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
You know, I've often wondered about that too but it seems like every dyno session I've seen or seen pics of has the WO in the tailpipe just like you described. I've always wondered if that's because it's the easiest place to put it and "close-enough" or if it really makes no difference.
Another thought is that you would think a cat would make the exhaust even leaner once it passes though it so if you're still reading rich then does that mean it was even richer before the cat? Just a thought. -Jeff
Old Dec 22, 2002 | 12:22 PM
MSR's Avatar
MSR
you can't trust the reading if the car has catalytic converters. on cars with converters, the only way to get a good reading is to use a screw-in sensor before any cats.
with totally stock (LT1) vette exhausts, this is near impossible. you can't weld a bung onto the stock manifolds, and there's hardly room in between flanges and cats.
with longtubes it's easy. just weld a bung into one of the collectors, at an angle where it's even possible to screw in the sensor without jacking up the car. i did this on mine, works great.
Old Dec 22, 2002 | 12:59 PM
89vette's Avatar
89vette
Default Re: Wideband O2 Sensor ? (MSR)
:iagree: I did both before cats and the tail pipe. Very different readings. The tailpipe sniffer showed lean but the sensor before the cat showed rich.
Old Dec 22, 2002 | 01:12 PM
ELEVENS's Avatar
ELEVENS
Another thing to consider, the AIR System pumps air down a tube and into the cat. Remember, air is about 20% oxygen... :eek:
Old Dec 22, 2002 | 05:04 PM
MSR's Avatar
MSR
Default Re: Wideband O2 Sensor ? (ELEVENS)
on LT1s (dunno about earlier vettes, never looked), the AIR pump goes into the manfifold very close to the cylinder head. therefore, it would affect the reading regardless.
no AIR injection at WOT, i think, which is why that's not an issue. i think the AIR pump stops so many seconds after startup, before it goes into closed loop, anyhow. after all, how could the stock ecu work in closed loop if the exhaust had the air injection going?
Old Dec 22, 2002 | 05:35 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Seems that the LT1 cats do not use the AIR pump to add O2 to the system. On my 89 the AIR pump is diverted to the second section of the cat to provide O2 to facilitate reduction of HC an CO. During warm-up the AIR pump sends outside air to the exhaust manifolds to burn-off excess HC from the rich start-up mixture, and aid in speeding the heating of the O2 sensor and cats.
Regardless, I find it bad practice to place a sensor after the cat. There is very little O2 left after proper combustion, but I fear that what is present at the tail pipe is very different than before it enters the cat.
If your AIR pump feeds the cat, it is certainly not accurate - at all. Even if it doesn't, I don't see how it can be accurate after all the heat and processes going on in the cat.
Pete
Old Dec 23, 2002 | 01:18 PM
lead_foot's Avatar
lead_foot
Default Re: Wideband O2 Sensor ? (89vette)
Thanks for your thoughts guys. Sounds like this method provides some indication at WOT, but is far from completely accurate. :)
To Wideband O2 Sensor ?
