Bose Antenna Cutoff Switch
Old Oct 6, 2021 | 06:28 PM
SnorT91Man's Avatar
SnorT91Man
Default Bose Antenna Cutoff Switch
Which makes more sense when installing an antenna cutoff switch, the relay coil activation wire or the relay high-current wire? I can make a case for either option, but maybe I’m overlooking something.
Thank you!
SnorT91Man
Old Oct 6, 2021 | 08:56 PM
SnorT91Man's Avatar
SnorT91Man
Default Reply
Excellent remark, thank you! I knew that the orange wire powered a lot of things but it just didn’t occur to me that they would all be turned off when the antenna was down. Now I understand why everybody uses the pink wire.
