Start Interrupt Relay Help
Old Oct 7, 2021 | 09:29 PM
Bill_'s Avatar
Bill_
Cruising
Default Start Interrupt Relay Help
This is somewhat to a follow-up post, but I’ve made some progress on getting my ‘85 to run. So I’ve been digging into the Security System that comes on the vette and I’ve gotten to the point where the Starter Interrupt Relay clicks, however I still get no cranking. The security light stays solid, no matter if I pull the fuse behind the DIC(it will dim when I go to crank). My next step is to check if the connections at the starter and the starter itself are good. However, I still can’t seem to get the gauges or radio to turn on. I checked the fuses and they seem fine. I also do not hear the fuel pump priming at all. So if anyone has any suggestions, I’d highly appreciate it as I keep digging into these things.
Additionally, could someone tell me what this connector goes to under the dash?
