O2 sensor pin at ecu
Old Oct 17, 2021 | 03:05 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default O2 sensor pin at ecu
Hi,
please help me
some
years ago when I installed headers, I used heated o2 sensor with a relay to switch on.
some weeks ago I sent the car to replace exhaust gasket to copper.
I dont know what happened but Indont have signal from o2 sensor to ecu
and I cant found the oem pink-purple cable from oem 1 cable 02 sensor.
could somebody please let me know which pin at ecu is the o2 signal input ?
thanks in advance
Old Oct 17, 2021 | 03:19 PM
WVZR-1's Avatar
WVZR-1
A16 PPL cir412
You don't have a FSM for your '91?
Old Oct 17, 2021 | 04:12 PM
Eduardo L98 1991
Originally Posted by WVZR-1
A16 PPL cir412
thanks for your answer
to technical for me, the ecu have numbers marked ?
I dont have fsm, only haynes manual inside car, the car is at other city . On this days I will try to repair this,
i dont remember if at haynes manual have the numbers of ecu connectors
i will check
Old Oct 17, 2021 | 04:18 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
A16 PPL cir412
They come highly recommended...
https://www.corvetteforum.com/forums...ts-please.html
Old Oct 17, 2021 | 05:26 PM
CorvetteRules's Avatar
CorvetteRules
When a member of the forum asks a question the question should not be responded to with "don't you have a FSM". It comes across like that member is being told "why are you bother us with your question?? Go buy one and find the answer on your own !!!. One of the reasons many owners subscribe is because they can reach out and get a fellow member here to help them.
I can tell you that I had the FSM for my 91 and not ashamed to say some of the diagrams in the electrical book were beyond my ability to read and follow. My advise for those here that constantly use "you need to buy a FSM" as their answer, it might be better for them to not reply at all.
Old Oct 17, 2021 | 06:11 PM
Eduardo L98 1991
Originally Posted by stew86MCSS396
thanks a lot !!!!!
Old Oct 17, 2021 | 06:15 PM
Eduardo L98 1991
What is a good place to connect the switched signal for the 02 sensor relay ?
some gave me the advice some time ago from wiper, but I found that on mine is intermitent
thanks in advance
Old Oct 17, 2021 | 07:14 PM
383vett's Avatar
383vett
WVZR1 has helped hundreds if not thousands of members over the years. If you read his response carefully, you will see that he did answer the op’s question in detail. To suggest that someone purchase a FSM is not out of line. Had WVZR1 had not answered the question, that would have been a different story. And by the way, the word you want is ADVICE.
Old Oct 17, 2021 | 07:30 PM
CorvetteRules
Originally Posted by 383vett
WVZR1 has helped hundreds if not thousands of members over the years. If you read his response carefully, you will see that he did answer the op’s question in detail. To suggest that someone purchase a family is not out of line. Had WVZR1 had not answered the question, that would have been a different story. And by the way, the word you want is ADVICE.
Sorry, but my opinion hasn't changed. But with that said I see no reason to make it into a let's analyze the meaning of the post, because when push comes to shove neither of us can read minds.
Old Oct 17, 2021 | 08:02 PM
WVZR-1's Avatar
WVZR-1
Actually bothers me NOT!! I always ask! OP is adding/modifying so all the more reason to ask.
Had he replied yes I'd have supplied a page reference in the FSM for him. OP didn't get A 16 & PPL. OP then returns to mention he's maybe struggling with more wiring!
I'd say a FSM would be a reasonable purchase. Seeing the OP's location I also mentioned to him I could supply one + other information 'today' or same day requested!!
To O2 sensor pin at ecu
