I am trying to replace all my coolant sensors. I understand each serves a different purpose. I believe I found the one for the drivers side as well as the one under the manifold.
I am trying to find the sensor that goes on the Pass. side. I believe from what I read, each have a specific purpose. If any one can enlighten me, I would appreciate it.
mostly I am looking for the pass. side one. or if someone can explain this or get me part numbers, it would be appreciated.
Bob R
88' Conv.
PS, if this isnt the correct place for this please advise, kinda new to this
If you have one between 1 & 3 (driver side) that would be for AUX FAN(if the car has one in front of the cooling radiator/condenser), the gauge sender should be between 6 & 8 (passenger side). The ECM temp sender is front of the intake.
It seems you maybe don't have a FSM (Factory Service Manual) and I'd suggest you get one.
