LT1 removal question
Old Oct 28, 2021 | 05:40 PM
Impala Balko's Avatar
Impala Balko
Default LT1 removal question
I have a 94 coupe with the LT1/6 speed that has a spun bearing. I have the replacement engine on the stand and I am looking to remove the engine out of the car. Now as far as the wiring harness goes can I unhook the engine harness from the car and remove the engine harness with the engine or is it tied into the car in way too many locations. Or is the better approach to unhook all the sensors and pull the harness off the engine and set it aside.
Old Oct 28, 2021 | 06:09 PM
JD1964's Avatar
JD1964
I would lay a large soft blanket like a moving blanket over the windshield area. Then as you disconnect harness attachments from the engine you’ll eventually be able to lay that portion back over the windshield. You may need to use a string line or whatnot and hold it back from the engine bay over the windshield. Then when the new engine is in place you can flop the harness back down. I see no need to completely remove it.
Old Oct 29, 2021 | 12:07 AM
ajp01's Avatar
ajp01
There is actually a good reason Not to remove it. Those connectors at the firewall, the large block connectors which have many pins in them, are likely to be brittle from years of heat cycles and may well crack to sh*t when you remove them. Getting them to connect back is likely to cause you at least one issue electrically, which as you know can be hell to isolate the cause exactly. I agree - leave the harness attached to the car and lay it back on the windshield or around the engine bay.
No matter what you're going to have to remove each sensor connector from the engine side to move onto the new engine. May as well reduce the possibility of chances to just that end of the wiring harness. It's likely some of those Weatherpak connectors are going to break also, and they'll need repair / replacement.
Great avatar by the way....
Old Oct 29, 2021 | 11:33 AM
Impala Balko
Thanks for all the replies I guess this cements the idea that I have to un hook all the connectors and set the harness aside... does anyone know where I can find a wiring diagram so I know where to look.
Old Oct 29, 2021 | 03:19 PM
JD1964's Avatar
JD1964
I recommend you get blue painters tape and a sharpie pen. When you are taking things apart like unhooking wiring harness things, wrap a piece of tape around and label where it goes. Also, get ziploc sandwich bags. You can put nuts and bolts in them and also label them with the sharpie.. Some fasteners can also be screwed back into the component they belong with until you are ready to put them back on. A little time organizing can save alot of time later. Taking pictures of various things before disassembling can help when reinstalling too.
Old Oct 29, 2021 | 05:36 PM
jayjones's Avatar
jayjones
I pulled my LT4 out last week. Everything is brittle AF on both ends. I'm going to replace most of the sensors and wire in new connectors. Either that or just make a new wiring harness. Now that I've removed everything, a new harness doesn't seem that hard to make.
Old Oct 29, 2021 | 07:33 PM
Impala Balko
I bought a Label maker for this project... this was a school of thought I was definitely prescribing too
To LT1 removal question
