Lockup
Old Oct 31, 2021 | 03:37 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Lockup
automatic L98 1991
HI,
Please help
I believe I have a lockup problem, at highway on 4 gear the shift light mantains on
the trans is recently rebuilt (transgo -great), new converter
how can I test lockup signal to the trans, if I remember correctly jumping pins A & F on the ALDL connector., then I removed the trans connector, what I need to check this ? 12v ?
what about the brake pedal swicth ?
hope you can help me on test procedure
thanks in advance
Old Oct 31, 2021 | 06:58 PM
s carter's Avatar
s carter
A quick test is to go for a ride let all temperatures get up to operational, then on flat road or slightly graded. At around 45/50 MPH Break lightly enough to get brake lights on left and hold throttle steady with right.
If lock up is working the RPMs should jump, release brake RPMs should drop and car should lug a bit
