Rear Right Running Light Issue
When I pull my headlight switch, my headlights pop open, and my rear running lights activate.
The passenger running lights work at their normal brightness, however my driver side running lights are as bright as the brake lights, almost as if the brake lights are eternally on when the running lights and headlights are active.
I would like to know why this is, as well as a possible fix.
-Also, my driver side blinkers don't work, so could it be the turn signal switch in the steering column?
----Anyway, thanks
