Code 43 esc
Old Nov 1, 2021 | 04:44 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Code 43 esc
HI,
Please help me with this
my engine sudenly stops, afetr no spark test I replaced coil , engine starts but I have service negine soon lamp, with tuner pro scanner reads code 43
code 43 can be esc or knock sensor
I replaced the coil with a new prstolite c833, that the only one that I found locally
can be posbile that esc module is defective too and this is the reason of error code ?
________________________________________ _______________________
car was running properly , but I founf that the timing conector was unhook, this can be the reason of coil esc problem ?
Old Nov 1, 2021 | 04:57 PM
ajp01's Avatar
ajp01
Yes. But first, unhook the battery for a while then reconnect, this will clear your codes. Then see if the car is running correctly with the EST timing connector re-attached. If you still receive a new code 43, then research further.
Old Nov 1, 2021 | 05:08 PM
Eduardo L98 1991
Errors code was cleared several times with scanner, also I disconenct battery for a while
the error code is inmediatly
Old Nov 1, 2021 | 05:13 PM
ajp01's Avatar
ajp01
Do you have a Factory Service Manual to further troubleshoot the issue?
Old Nov 1, 2021 | 05:18 PM
Eduardo L98 1991
no I dont
Old Nov 1, 2021 | 05:28 PM
don hall's Avatar
don hall
Click on upper left corner for additional info:
https://www.corvettebuyers.com/c4vettes/codes.htm
To Code 43 esc
