SuperRam Runners/Valve cover clearance
Old Dec 23, 2002 | 05:08 PM
chucks88's Avatar
chucks88
Default SuperRam Runners/Valve cover clearance
How much grinding does it take? Those valve cover walls aren't that thick. I've been grinding away for quite some time and I still can't get them on.
Old Dec 23, 2002 | 05:23 PM
tommelton's Avatar
tommelton
Default Re: SuperRam Runners/Valve cover clearance (chucks88)
That is more than I had to grind. But mine were still a snug fit.
Tom Melton
82 CE
86 Z51 Coupe
Old Dec 23, 2002 | 05:25 PM
scorp508's Avatar
scorp508
Thats way more than I took off. I just hit the bench grinder and took a few thousandths off of the entire side. :)
Old Dec 23, 2002 | 05:33 PM
Bluevette85's Avatar
Bluevette85
If you're using Roller Rockers, did you remove the drip tabs? When I test fit mine, they wouldn't go down all the way because the drip tabs were hitting the rockers.
Old Dec 23, 2002 | 05:47 PM
J Z06's Avatar
J Z06
I do not think mine have any ground off(I could be mistaken) If you go too far with yours or can't get them to work out, I know mine will. . . I'll cut you a great deal :) (Only if necessary)
Old Dec 23, 2002 | 05:50 PM
MITCH's Avatar
MITCH
chuck i never had to grind my valve covers they always fit my drip tabs where grinded off to clear 1.6 rockers.
mitch
Old Dec 23, 2002 | 06:32 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: SuperRam Runners/Valve cover clearance (MITCH)
They will fit you just have to coax them a bit. I didn't have to grind any, but did just to make it a bit easier. They always require a slight smack to get them past that tight point. Once past they move freely.
Old Dec 23, 2002 | 07:01 PM
Caboboy's Avatar
Caboboy
Yikes, thanks for the heads up :eek:
I'm gonna have mine powder coated... looks like I better test fit them first though :yesnod:
Old Dec 23, 2002 | 09:06 PM
chucks88's Avatar
chucks88
Default Re: SuperRam Runners/Valve cover clearance (Caboboy)
O.kay, I got the drivers side on but I may have screwed up my assembly sequence. I can't get the #7 injector connecter on its' injector. Was I supposed to wire up my injectors before putting the runners and plenum on.
If so how do you get the valve cover on with all the injectors plugged in?
Old Dec 23, 2002 | 09:12 PM
scorp508's Avatar
scorp508
Ahh yes #7.
Unplug #5 and then stick a screwdriver in their and twist #7 so that the plug is kind of facing towards #5. It isn't easy, but can be done! :yesnod: Once you have it on twist the injector straight again and put #5 back on. :)
Oh and you just have to kind of pull up on the wiring harness to slip the cover in under it.
Old Dec 23, 2002 | 09:18 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (scorp508)
That wierd I did not have to take any off the valve covers. As for the injectors I can get all mine on and off with no trouble at all. :confused:
Old Dec 23, 2002 | 09:43 PM
chucks88's Avatar
chucks88
Default Re: (ski_dwn_it)
Jesse! You got your SuperRam on without removing your covers :skep:
Thanks Brian, I'll give that a shot.
Old Dec 24, 2002 | 03:09 PM
Vic'89's Avatar
Vic'89
Default Re: (chucks88)
Is the SR on yet ?
Vic
Old Dec 24, 2002 | 03:21 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
No, No...I was saying that I did not have to take *any* off the sides like the first pic showed.
I have taken it off with the RR on where many claim you have to remove a few of them as well.
Old Dec 24, 2002 | 03:32 PM
scorp508's Avatar
scorp508
He has an edlebrock base right? It might set the runners slightly lower than the accel one. It wouldn't take much to make a big difference.
Old Dec 24, 2002 | 03:36 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Good point. I think we all have accell bases... :cheers:
Old Dec 24, 2002 | 03:46 PM
J Z06's Avatar
J Z06
Default Edelbrock Base
Good call Scorp.
It is an edelbrock base. :yesnod:
To SuperRam Runners/Valve cover clearance
Old Dec 24, 2002 | 05:02 PM
chucks88's Avatar
chucks88
Default Re: Edelbrock Base (JD 90 383)
Yep, It is an edelbrock base. However, "Mitch" whom I bought the base, runners and plenum from, had no valve cover clearance issues when it was on his L98.
Jesse, I just plain read that wrong-my bad
Vic, you can't rush an artist :D
Here is the latest pic(makes a good mini work bench too) I didn't work on it today and probably wont tomorrow either.
Happy Holidays all :seeya
[Modified by chucks88, 5:03 PM 12/24/2002]
Old Dec 24, 2002 | 05:24 PM
Corvette0096's Avatar
Corvette0096
Default Re: Edelbrock Base (chucks88)
Things are looking good there Chuck. I have no idea why you are having to trim your covers down. Maybe the intake like Scorp said.
Old Dec 25, 2002 | 01:17 PM
J Z06's Avatar
J Z06
That photo looks really good Chuck!
Did you run the fuel injector wire harness UNDER the runners? Mine before the DFI we're there. It looks much better that way(to me).
Good luck getting the rest of it together,and I hope things go smoothly afterword. :cheers:
