Distributor part identification and removal help
Old Nov 14, 2021 | 09:45 AM
chris3moore's Avatar
chris3moore
Default Distributor part identification and removal help
This is on my '84 resuscitation project - I found these abraided or chewed wires that run from the ECM to the distributor, but I can't identify the component. What is this called? Where can I get one? There *is* a connector behind the distributor.
And, and hints or tricks getting to it besides reviving the distributor?
Thanks!
Old Nov 14, 2021 | 09:57 AM
84 4+3's Avatar
84 4+3
GM 1979733
Or
1986260
Old Nov 14, 2021 | 10:06 AM
WVZR-1's Avatar
WVZR-1
The grommet to distributor housing on yours is in 'excellent' condition. Many I'm sure are envious. I believe you splice sections to salvage it. What condition are the connectors in?
It's called a terminal block and hasn't been available from GM/ACD or others for years. GM# is/was 1986260. A few years ago someone mentioned buying one. Search for 1986260 and several threads will be linked. One of them has phone info I believe.
Davis DUI does a 1986260-PD that might be used for a splice repair but it seems to be way 'over priced'. I believe the mating connector is likely correct.
Originally Posted by 84 4+3
GM 1979733
Or
1986260
Where did you come up with the 1979733 info?
Old Nov 14, 2021 | 10:14 AM
84 4+3's Avatar
84 4+3
Originally Posted by WVZR-1
It's called a terminal block and hasn't been available from GM/ACD or others for years. GM# is/was 1986260. A few years ago someone mentioned buying one. Search for 1986260 and several threads will be linked. One of them has phone info I believe. The grommet to distributor housing on yours is in 'excellent' condition. Many I'm sure are envious. I believe you splice sections to salvage it. What condition are the connectors in?
I had it written down on a piece of paper from a friend at a dealer from a few years back. It may have been for capacitor side on an older HEI setup though. That one had a question mark next to it, the 1986260 was underlined and circled so I assume that is the one I sought out. Probably should've just listed the one, sorry about that.
Old Nov 14, 2021 | 02:36 PM
chris3moore
My task today is to try to get to the connector. If I can repair it I will, otherwise I'll get the Davis unit, overpriced indeed.
Old Nov 14, 2021 | 03:01 PM
WVZR-1's Avatar
WVZR-1
If you get to the connector I seriously doubt you'll need the Davis unit. EFIconnection.com likely has it as a 'pigtail' or just a shell that you could add terminals, seals and repair.
Wire colors are PPL/WHT, TAN & BLK?
Old Nov 14, 2021 | 09:45 PM
joeld's Avatar
joeld
Is this what you need?
Joel
https://www.ecklerscorvette.com/1984...-110951-1.html
Old Nov 14, 2021 | 10:09 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by joeld
That's less than 10$ worth of readily available connector shell, terminals and wire! That would be a foolish buy!!!
Old Nov 14, 2021 | 11:20 PM
chris3moore
Hi Joel, that looks like the connector. Can't reconcile the price though.
Chris
To Distributor part identification and removal help
