Stroker question
Old Dec 24, 2002 | 10:33 AM
Glasman66's Avatar
Glasman66
Default Stroker question
What are the benefits of going with a stroker compared to stock bottom end?
Old Dec 24, 2002 | 10:42 AM
SkarodoM's Avatar
SkarodoM
Default Re: Stroker question (Glasman66)
It depends entirely what your goals are, as to whether a stroker would suit you. Most people seem to want something with lowend power so it feels fast. For a play car, you aren't racing for $ in all likelyhood.. so that can be alot of fun. If you want to go fast, you need to turn it IMO.
Spin it, gear it, and make it hook up. Simple :steering:
Old Dec 24, 2002 | 10:59 AM
Timmy!'s Avatar
Timmy!
The torque is the main benefit...
Old Dec 24, 2002 | 11:14 AM
Phobos84's Avatar
Phobos84
Will give you lots of bottom end power. Doesn't take away from upper rpm power it's just that if you go with a normal cast or forged crank they are a lot heavier and kill rpm potential. A super light crank will solve this if you feel like spending $2000 on one.
Old Dec 24, 2002 | 11:25 AM
SkarodoM's Avatar
SkarodoM
Default Re: Stroker question (Phobos84)
Volumetric Efficiencyis directly related to piston speed. So yes, with the same setup, you will lose topend power... and mid-topend power is what wins races. Again though, if you're just rolling around and playing... I don't think it matters that much.
Old Dec 24, 2002 | 11:38 AM
Phobos84's Avatar
Phobos84
Default Re: Stroker question (SkarodoM)
I did not know that. Sorry. I do know that even if it kills top end you can still build a 383 with a lot of top end. Take a 400 block and de-stroke it with a 350 crank and punch it .030 over. With a good cam and port work you will get good torque and be able to run to 7500rpm easy.
Old Dec 24, 2002 | 12:35 PM
SkarodoM's Avatar
SkarodoM
Well it wouldn't be as big a deal if people didn't undercam/head their stuff so severely alot of times.
There you go, big bore, short stroke.. the way to NA happiness :D. I'd personally never run more than a 383... and definitely not some of the big inch strokers people put together with godawful bore/stroke ratios. Same reason a 396BBC will stomp a 396sbc.. where it makes the cylinder pressure :). Of course, everyone's obsessed with inches.. and they're great, but IMHO not so hot when you begin to build something akin to a large 305. Never the less, that's generalizing what most people do. Properly built, it's not like it'll be slow by any stretch of the imagination :)
I know people hate to hear that :boxing.
Old Dec 24, 2002 | 12:49 PM
h rocks's Avatar
h rocks
If you're talking strictly about straight line racing, I agree. Spin it! I guess that's one of the reasons the 1/4 mile guys like the 377. I need to have a broad power band. A big bad flat torque curve is what helps get off corners quickly and beats the other guy point to point. (presuming you drive it!) My SR 383 has yet to be dynoed, but all the sims show big TQ and power to 6400+. Haven't spun it over that yet, but it sure didn't lay down AT ALL. Should be enough to get me into trouble this coming season. :D
Old Dec 24, 2002 | 01:11 PM
SkarodoM's Avatar
SkarodoM
Default Re: Stroker question (h rocks)
99% of what we do is for road race applications & it's still all big bore, short stroke, and spin it. Straight, curved, whereever you're accelerating, but obviously.. things change when it's more street than race, or even 50/50 IMO.
Either way you go, it's all about the entire package obviously :).
Gah! Hamtime :D
Old Dec 31, 2002 | 12:16 PM
Glasman66's Avatar
Glasman66
So I guess my question is, When I rebuild should I stick with the 350, and just make her breath like a *****?
I think that would be more cost effective.
I also see that you are running shorties. My tuner said these were the the best way to go unless you are looking to go into the 500 and up HP ranges.
Old Dec 31, 2002 | 06:21 PM
Bruce's Avatar
Bruce
DO you want power????? Then stroke it and blown it. :)
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Old Dec 31, 2002 | 07:36 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Stroker question (Bruce)
quote(It depends entirely what your goals are, as to whether a stroker would suit you. Most people seem to want something with lowend power so it feels fast. For a play car, you aren't racing for $ in all likelyhood.. so that can be alot of fun. If you want to go fast, you need to turn it IMO.) so skarodom my car just feels fast but realy isnt that fast is that what i am reading from your above statsmants and i should turn it to 7500 rpm because where i shift at a measly 5400 rpm there is no power down there ohhh okay now i under stand there i thought i knew what i was doing all these years now i finally see the light :crazy: :cheers:
Old Dec 31, 2002 | 07:40 PM
Corvette0096's Avatar
Corvette0096
Default Re: Stroker question (CORKVETTE1)
:lurk:
Old Jan 1, 2003 | 03:46 PM
95vettski's Avatar
95vettski
If your planning a rebuild .30 over 355ci for a few hundred dollars more you can drop in a cast 3.75 crank and make it a 383ci. The additional stroke will provide more torque and the engine will tolerate more cam.
Long tube headers will provide more hp and tq over shorties regardless of total output. They will benefit larger and/or higher spinning motors and the gains will be more noticeable.
Old Jan 2, 2003 | 10:10 AM
FELNGR8's Avatar
FELNGR8
Does anyone use the 400 block destroked to 377 for an LT1 or LT4 buildup. That would make an awesome stock looking motor, but are the block to head differences too much of an issue? I love to spin my engines, and a stock looking LT1 that revs to 7500 or 8 grand would be something else.
[Modified by 94lt1torchred, 3:13 PM 1/2/2003]
Old Jan 2, 2003 | 10:57 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Cork that is what I have been trying to tell you all along....one of these days you will see the light :D :lol: :jester
To Stroker question
