I'm looking for some info about somebody here in Scandinavia whith a dyno. I also need to get a reprogrammed chip.
Unfortunately there is nobody here that has a dyno big/strong enough.
I made some major mods on the engine so it needs to be run on the dyno.
New sig is coming up soon.......
Tnx.
:steering: :skep: :steering:
Dear Finland. there are several rearwheel dynos in your country one EVEN in Turku :rolleyes: .If you have stepped out of rearwheel dynos scale,few superflows are less than 250 km range (10-1500hp) As for burning proms.Forget it! Bay fully programmable Haltech ECM wich is an easy bolt on to your orginal harness and you have total control for everything and will gain a lot of power when tuning in dyno. Yes Haltechs are availble at Finland too... from little town called Pori :D
So no need for paging Scandinavia,just look around and shop locally.
