How should this work? [setup]
Old Dec 26, 2002 | 08:03 AM
devilfish's Avatar
devilfish
Default How should this work? [setup]
Its not for me, I already order my stuff. I just thought that his could be a good and cheap setup..
Holley stealth ram (with mod plenum to clear the hood) , lt4 hot cam kit, ported 113 alu heads, headers.
I know about the hood issue and the HSR. But you think you should have a strong car?
Old Dec 26, 2002 | 08:42 AM
bogus's Avatar
bogus
Default Re: How should this work? [setup] (devilfish)
Will the LT4 hot cam fit in an L98???
Old Dec 26, 2002 | 09:04 AM
LPDesRoche's Avatar
LPDesRoche
Default Re: How should this work? [setup] (bogus)
Yes, all LT1 and L98(roller) cams are the same as far as interchanging them. Only difference is the pin length on some of them.
[Modified by LPDesRoche, 9:04 AM 12/26/2002]
Old Dec 26, 2002 | 09:42 AM
bogus's Avatar
bogus
Default Re: How should this work? [setup] (LPDesRoche)
I wasn't sure... considering the opti and stuff. thanks!!! :thumbs:
Old Dec 26, 2002 | 10:00 AM
devilfish's Avatar
devilfish
so how would you think that combo would work? I think it should work fine, worth 350 hp :)
Old Dec 26, 2002 | 10:55 AM
devilfish's Avatar
devilfish
tt
Old Dec 26, 2002 | 11:04 AM
scorp508's Avatar
scorp508
Don't modify the stealthram. :nono: Modify the hood! Holley designed that plenum to be a certain volume, I wouldn't go messing it up no matter how little it was. Besides... C4s with a slight hood rise look mean.
Old Dec 26, 2002 | 11:09 AM
devilfish's Avatar
devilfish
Default Re: (scorp508)
well as long you keep the propper volym you should be ok. You clould make the plenum box wider and lower and still keep the same volym.
Old Dec 26, 2002 | 04:35 PM
vader86's Avatar
vader86
Default Re: (devilfish)
Well you know just making the box wider will still change the characteristics of the whole thing. Making a MR/SR wider wont necessarily improve your flow or power numbers will it? You could still cause some type of lean/rich condition in one cylinder when you mess with stuff like that.
I would like to see a C4 hood thats more subdued like the C5 high rise hoods, but all the ones they make for us (that ive seen) are too high and too ugly.
Just talking about the motor though, id say the Stealthram and Hotcam would make a good combo.
Old Dec 27, 2002 | 05:25 AM
devilfish's Avatar
devilfish
Default Re: (vader86)
hmmm.
By how much does the stealth ram go to high for the vette hood? 1 inc?
To How should this work? [setup]
