1991 Misfiring when warm
The next place to look might be the Ignition Control module under the rotor inside the distributor. That device is mounted on a heat sink and needs the thermal transfer material under the Module or else it will fail prematurely. These modules will start to fail when they get Hot.
I have seen Carbon tracking inside the Distributor cap that caused a regular miss. If you have a black light handy you can see the carbon tracks themselves if they are present
The other part that could do this is a would be the MAP or MAF sensor. When a MAP/MAF goes out the drive ability goes with it. Mine failed in my DD and it would miss under loads at first. On my C4 I have the MAF and they are notorious for having issues like you are describing. be sure to check BOTH relays that operate the MAF (IF you have the MAF).
Misfiring when Warm could also be an injector issue. Have you tried any Fuel Injector Cleaner to see if that helps?
Even a Spark Plug Wire can induce misses as they warm up and the resistance becomes an issue. I like to check the spark itself to be sure it is a HOT spark using a "gap widening test tool". I like to see the spark itself to know that it is working properly.
Hopefully others will pitch in their thoughts as well.
Merry Christmas to you and your family Sheriffjim!
It also has a service engine light after the car started bucking, I'm going to go figure out what that is for
You need to fix these codes first.
I attached a few pages from the 1991 Factory Service Manual on the IAT and O2 sensors.
O2 sensors do go bad and some people change them as a regular maintenance item.
Also note that you have a MAP (Manifold Air Pressure) system of measuring incoming air volume vs the MAF system used on 85-89 L98's. (assuming yours is stock).
I would do a full tune up (plugs, wires, cap, rotor, timing check) after you fix the Code 13 and Code 23 errors.
I dont know how long it takes the lt1 ECM to make the corrections once you fix something... could be it needs time to do so? Im being optimistic.
The only way I know of to avoid replacing parts is with an oscilloscope. You can pretty reliably diagnose things like your optispark without replacing it and then having done that incredibly long painful job winding up with the same problem and an inferior aftermarket distributor.
Sure, you will spend a little, and there is a learning curve but incredibly satisfying knowing you can diagnose without replacing parts and kneeling down to the good Lord before you turn the key. If you search I made a post on this where I sourced brand new for peanuts; ccp made unfortunately.
Beyond that, follow the service manual and make sure you have a diagnostic tool that goes deep into GM values.. a tech II built by the ccp unfortunately will do this.
Or; throw parts at it. at least you know they are new.. Im so done tossing parts at cars on a hunch.
Merry Christmas.
PS.. Sorry if this is not an lt1.. I forget if 91 is included. Same applies though for the most part..
I have a theory that the coolant temperature sensor might be faulty because a previous owner overfilled the coolant (completely filled the expansion tank), and the coolant level sensor went out less than a day before the issue started occurring, now displays low coolant light even though system is full. I honestly didn't realize the coolant was overfull until the light came on, and am in the process of getting what I need to flush and refill the system. From the charts I mentioned I noticed that the coolant temperature sensor was part of the ECM consideration for the air/fuel mixture. No SES light though... Either way I'm still testing, I won't rule out ignition though.
Thanks for the help and have a Merry Christmas!
