corvette cam
Old Dec 26, 2002 | 02:56 PM
vettesweden's Avatar
vettesweden
7th Gear
Default corvette cam
i have 1985 vette and i have just buy a summitcam k1107 and wondering if it go with my tpi computer .i have also buy a pete jackson geardrive (noisy).... i have also change my heads on my engine to 461 iron heads double humps with 62cc chambers ..and also matchporting intake ,runners plenum + headers ........the car is a 1985 z51 4+3 . :confused [IMG][/IMG]
Old Dec 26, 2002 | 04:28 PM
vader86's Avatar
vader86
Default Re: corvette cam (vettesweden)
Do you have the duration and lift numbers on this cam?
Old Dec 26, 2002 | 04:35 PM
vettesweden
7th Gear
yes this cam have 234 244 "050 lift 488 in 510 out lobe 114 i have buy it from summit :rolleyes:
Old Dec 26, 2002 | 04:40 PM
vader86's Avatar
vader86
You will need to have your computer chip reprogrammed to work correctly with such a large cam.
I also would suggest you port your plenum, runners, and base manifold to let that engine breathe if you have not already.
Old Dec 26, 2002 | 04:45 PM
Corvette0096's Avatar
Corvette0096
Default Re: corvette cam (vader86)
:iagree:
Old Dec 26, 2002 | 05:14 PM
vettesweden
7th Gear
ok thanks the intake and plenum is ported and the heads is ported too .i have 882 heads before and now it is 461 heads with much better flow i think it.s flow 180cc intake the old heads flow 137cc intake what do i get a new chip from ...... it.s hard to find here in sweden maybe ecklers have them ??
Old Dec 26, 2002 | 06:33 PM
Mark85Vett's Avatar
Mark85Vett
You might have a problem with that Pete Jackson setup giving false knock counts to the ECM, retarding your timing
Old Dec 26, 2002 | 06:43 PM
2manyC4s's Avatar
2manyC4s
Default Re: corvette cam (Mark85Vett)
The 85 ECM is too slow to give a stable idle with that cam. Best fix is to rewire to 86-89 ECM and get a custom prom for that.
Old Dec 26, 2002 | 06:49 PM
vettesweden
7th Gear
Default Re: corvette cam (2manyC4s)
ok thanks :)
Old Dec 26, 2002 | 10:59 PM
vader86's Avatar
vader86
Yeah an upgrade of ECM is a good mod to do when you do this cam, but for the chip itself id recommend Ed Wright, http://www.fastchip.com.
To corvette cam
