85-89 throttle cable
Old Dec 24, 2021 | 08:19 PM
johnfin's Avatar
johnfin
Default 85-89 throttle cable
Anyone make new throttle cables?
Old Dec 25, 2021 | 01:43 AM
jazfe's Avatar
jazfe
LoKar makes some good cables. I have a used one that I took off my 86 when I changed intakes and needed a longer cable if you need one.
Old Dec 25, 2021 | 09:57 AM
ctmccloskey's Avatar
ctmccloskey
Lokar is a good one but there are a few companies that make them for the Hot Rod market where they need specific lengths. I have a spare kit in my garage hanging on the wall since I have had a throttle cable brake away from home and remember what a PIA it was to replace it.
Just for fun I looked around and you are right, they are not available in a lot of Corvette Suppliers. EKLER'S says they sell the cable under part Number: 25-110970-1 Alt #:37836 and it costs $46 when they have it in stock.
EBAY also has a listing for it. Here is the information:
1985-1988 Corvette Accelerator Cable GM 10181278 and it is over $50 for a used one...
Good Luck and I will keep an eye out for the cables. If they are this hard to find Maybe I should get one as well just in case. The aftermarket ones will work just fine but they might look different.
To 85-89 throttle cable
