1993 lt1
Old Dec 25, 2021 | 06:31 AM
ME93's Avatar
ME93
Default 1993 lt1
Made a hard pass and after felt little shaky at idle and started running rough and.smoking left muffler only.
Pulled.over found dampner slight wobble. anyone have loose crank pulley dampner bolts?
Shut car off now hard starting. Pulled injector plugs while.running and found 3rd injector no response. what is the result of stuck injector open ? thanks guys.
Old Dec 25, 2021 | 08:52 AM
s carter's Avatar
s carter
If you have loose balancer bolts tighten them up before you oblong the bolts holes or have things fail.
Now the injector, first off the fuel rail pressure charge would be lost to the one or two stuck cylinders which would lead to a hard start as well gas running down cylinder walls thinning the oil with gas.(not good) Once running if they are truly stuck open it could keep needed pressure from other injectors causing poor performance, even though the pump volume would compensate and once again the thin oil because the stuck cylinders can't keep up on a good burn.
Old Dec 25, 2021 | 03:24 PM
Kevova's Avatar
Kevova
Injector problem shouldn't cause pulley bolts to loosen. Any previous repairs involving Opti? Pulley needs to be removed to change or check cap & rotor.or replace Opti
Old Dec 27, 2021 | 06:22 AM
ME93's Avatar
ME93
hooked up fuel pressure tester and fuel drops to zero as soon as i turn off engine.
Old Dec 27, 2021 | 09:47 AM
Whaleman's Avatar
Whaleman
You need to attack these three problems one at a time.
Old Jan 1, 2022 | 02:22 AM
ME93's Avatar
ME93
thanks for all the help guys.
Old Jan 2, 2022 | 05:34 AM
ME93's Avatar
ME93
noid test passed all receving power and pulsing
what injectors do you reccomend to replace gm junk from factory ?
To 1993 lt1
