L98 Harmonic Balancers
Old Dec 26, 2002 | 05:46 PM
GRX's Avatar
GRX
Default L98 Harmonic Balancers
...are they interchangeable? Like between '85 and other L98 years? :confused:
[Modified by GRX, 2:47 PM 12/26/2002]
Old Dec 26, 2002 | 06:14 PM
HWoods's Avatar
HWoods
Default Re: L98 Harmonic Balancers (GRX)
I had looked on the NAPAOnline web site some time back and it showed the 84 (cross fire) and all the L98 years that I looked at all used the same crank damper.
Old Dec 26, 2002 | 08:34 PM
gtsyellow's Avatar
gtsyellow
Default Re: L98 Harmonic Balancers (HWoods)
yes, and they can be bought new from GM, it's listed in the parts performance catalog. just a 6-3/4" damper. i even used one on my new motor.
Old Dec 27, 2002 | 11:52 AM
BLUE ONE's Avatar
BLUE ONE
Default Re: L98 Harmonic Balancers (gtsyellow)
Be careful :nono: I am sure the 86 on l98's are not the same as the 85 and earlier
I have been looking into dampers a lot latey and one is internally balanced (upto 85 )and one is for externaley balanced (86 and on ) 350's.
The external balance 350's use a different damper to the 400's which are also externally balanced.
:cheers:
Old Dec 28, 2002 | 05:31 PM
GRX's Avatar
GRX
Default Re: L98 Harmonic Balancers (BLUE ONE)
Sure, I know that the GM performance parts book specs a different one for 86 and above. Thing is I really don't know why its needed...nor does my machinist...nor does the manager at the local GM parts counter. The reason the flywheel is not neutral balnced on 86+ years is because the one-piece-rear-seal-crank for th 86+ years, lacks the 'balance' flange at the rear of the crank....like the 85 and prior years, had. So to make up for the missing flange, the flywheel for 86+ years, has a weight to compensate. Now the front of the crank is identical between all years. Given: 3.48" stroke. My new block has a one-piece-rear-seal; along with the proper crank; and I have a new 86+ flywheel. So the balancing guy is going to balance everything as follows: PISTONS+RODS+CRANK+FLYWHEEL+BEARINGS the balancer is going to be from an 85 or prior. Hopefully the snout on all these cranks have the same dimensions.
:thumbs:
[Modified by GRX, 2:36 PM 12/28/2002]
Old Dec 28, 2002 | 11:48 PM
corvette1990's Avatar
corvette1990
My 1990 original engine in the garage on a stand being rebuilt is and always was an internally balanced L98, with a one piece rear main seal. the replaced 2001 ZZ4 GM crate motor in the car is also internally balanced. The smaller balancer had to be put on the crate motor and it fit great, with the proper tools. Don't know where blueone is getting his misinformation from. :crazy:
Old Dec 29, 2002 | 07:21 AM
BLUE ONE's Avatar
BLUE ONE
Default Re: L98 Harmonic Balancers (corvette1990)
I got my info from John Ligenfelter....quote What many Chevy fans may not know is that ALL '86 and later chevy small blocks are externally balanced engines requiring specific flywheels. flexplates AND torsional dampers.
This rarely presents a problem because ALL '86 and later engines require the specific one piece rear main seal crank etc.
this quote is from his book on modifying sbc engines page 32 crank shaft and bearings section.
If he's wrong then i am wrong, i do not claim to be an expert in this area, i was just recalling what i had read recently and have just re read to make sure i was not miss quoting.
the explanation about the rear seal makes sence to me as it would make the crank external balance which could mean the damper would still be the same as an internally balanced pre 86 if all the weight is added to the flexplate/flywheel
I guess anyone can make a mistake even John :lol: If your machinist and chevy dealer are happy go with that or you could just double check by contacting Lingenfelter performance and see if its a typo.
:cheers:
Old Dec 29, 2002 | 11:27 AM
h rocks's Avatar
h rocks
If you attempt to internally balance your '90 L98, you will find that you need about $35 of Mallory metal to do it. They were/are externally balanced. If you go ahead an internally balance it, you should be able to use a small lightweight race balancer.
Old Jan 1, 2003 | 08:22 PM
Mad Maxwell's Avatar
Mad Maxwell
I'll go WAAAY out on a limb and offer my humble experience... I was researching a fluidamper for my '86. From info given me by various experts and my own observations - ie. balance weight on the flywheel, I determined that the engine was externally balanced.
I ordered the external SBC damper from summit and found it to be totally wrong. It has a large balancing hump on one side and was considerably larger in diameter. This damper is meant for 383's and 400's that are full external balance.
After more research, I determined that SBC's (non 400 crank based) are both internally and externally balanced. Internal on the front and external on the back.
I returned the damper and ordered the one specified for all 262-350's. It fits and works perfectly! :yesnod:
Old Jan 2, 2003 | 01:11 PM
GRX's Avatar
GRX
Default Re: L98 Harmonic Balancers (Mad Maxwell)
That's what I found after researching....thanks all for the input...I pick up everything today. :thumbs:
To L98 Harmonic Balancers
