Most power from L98 TPI
I know this isn't a popular topic and that there is a strong contingent of well educated members here who have little to no interest and perhaps even some disdain for the motivations behind this question, but nonetheless this is the best place to ask it.
I also know that this question has been asked in slightly different forms before, but there are some different considerations I would like to have addressed.
I am curious what sort of crank and whp numbers one could expect only doing "light" or "stage 1" modifications to an L98 motor. By this I mean the following sorts of things:
Long tube headers, cat delete, muffler delete, true dual exhaust with H or X pipe, high flow air filter (my understanding is that dedicated intake systems don't really gain much), mild throttle body, plenum, and runner porting, Smog provision deletes, and of course a good tune/chip...
Perhaps somewhere around 300whp?
I am also curious what sort of numbers one might expect from doing the following "medium" or "stage 2" modifications on top of the above described "stage 1" mods:
Aluminum heads like the AFR 195, FIRST TPI intake kit with their electronics, and a good tune.
Finally I am curious what numbers might be achieved with a "stage 3" build, pulling the motor, 383 stroking, intelligent cam decision, as well as all of the above "stage 1" and "stage 2" mods.
I am trying to plan out several years of L98 ownership and modification.
Thanks for your expertise everyone!
Max
Popular Reply
However, I went ahead and changed the compression, head flow, and cam in the simulation to those provided by Matt. The intake parameters used are the same used for the previous MiniRam simulation. There are a few assumptions here and they’re just going to have to be what they are because I really don’t have the time to keep this going on and on. I used the same cross-sectional area and volume for “Matt’s heads” as the Competition ported AFR195s. If the specs are actually smaller or larger for either, it is what it is.
The increased compression (10.8:1), head flow, and smaller cam with the 383 MiniRam ended up making about 20 HP more than the simulated 10:1, 383 MiniRam with the TFS heads and big cam (included for reference). That pretty much shouldn’t be a surprise to anyone. What may be surprising to some is the simulated ET for the 10:1, 10xTQ engine with the TFS heads, FIRST (same length as the TPiS with the increased CSA and airflow), and a 228/228-112 cam (estimated to make 1” less vacuum than the 218/224-110 cam). It is what it is – I just entered the numbers into the program and pressed “calculate”. I will say I believe the results and you either do or you don’t – no skin off my nose either way.
Just for additional clarification, I kept the gear ratio constant at 3.54:1 and entered the numbers generated by the engine simulation into the ET simulation – feel free to double check and make sure I didn’t make an entry error. The shift points for each combination are optimized as well as the launch “Slip RPM”. Most would not want to ride the clutch like that to get the best ET, but that’s what it took to get the best ET from each combinations.
I’m not running any more simulations - yes the Miniram needs more gear to run a better time, but the FIRST could benefit from more compression and head flow as well. It could go on and on, and on,,, and is another reason I don’t like bench racing and posting simulations. Not to be a dick, but I usually don’t put this kind of time into an internet post and really can’t keep this going much, if any, longer. I don’t mind dropping in from time to time and trying to help someone out, but I have a life and a job and really need to get my own ride up and running.
So, enjoy,,, or not
Even with your medium mods, you're looking at 300whp as a best case without a camshaft.
Before the 383, it was a heads/cam/rockers car. That shaved about 1 second+ off the 1/4 mile. The 383 shaved another 9 tenths.
On a 400 HP engine, that equates to about 40 HP assuming the heads, intake, and exhaust don't become restricted by the additional demand.
If you want big power, boost is going to be your best bet. (But not cheap.)
I have to balance labor/time with cost. Boost is off the table because I just want an NA car.
Any idea what the "stage 1" power might be like? Thanks!
Ultimately we went with a NOS 5150 package. This is the easiest and cheapest way to add a decent amount of CHP to the L98 engine. Stage 3 can be had with simply a pill adjustment.
OP: I just did your "Stage 1" essentially; I took an '89, fabbed a 2.5", true dual exhaust with no cats (still using stock manifolds). Did the "Free mods"; timing, no air filter, smog pump delete and 160 stat. Car made 240 RWHP, which is about 265 crank or so.
Next, I changed the intake manifold and made 276 RWHP, which is a bit over 300 crank hp...maybe 305 or so?
All of this was on a stock tune. No tuning done at all. I think if I added long tubes, 1.6 rockers and a proper tune, it could have kissed 300 wheel....maybe.
As to the "value" or gains form tunes....I've seen a HUGE range. I once saw a mid '90's LT1 Firebird gain 45 RWHP with a tune....watched it happen on the rollers, first pull, tuning, subsequent pulls and tuning with a final, 45hp gain. Later that same day, my own car, an '06 C6, gained a paltry 6 RWHP with a tune on the same dyno, same day, same tuner. I'd BET that the LT4 is tuned pretty well with not a lot of low hanging fruit, but maybe a little. Just a guess there.
Basically port out and port match everything. Siamesed runners, ported out plenum, bigger base intake manifold, headers, no cats, 1.6RR.
Stock base, I don't see it happening, that part has to go aftermarket, would be better if you can find larger AS&M runners and port match everything.
Then a tune of course.
But youre looking at some money that might not go along well with a second stage of mods, so you'd have to know what the end goal would be. I might not spend the coin for the base manifold or larger runners just to switch to FIRST later.
Which intake did you change to?
For the "stage 2" options, you can't get a good return on your investment (dollars:hp) unless you're willing to forget about the TPI and any other long-runner intake. I don't know why anyone would spend the ~$3000+ to get AFR heads and a fancy new intake and then choke it with 24" runners and the stock cam. If you want the heads in prep for future "stage 3" mods, I get it. But don't waste money on an intake that is always going to limit you to power at or below ~5500rpm. You need an intake with shorter runners that has real power potential, or those AFR heads and all the stage 3 stuff are mostly wasted. There's no way around that. The stock cam is also going to break your heart, so don't bother with the heads unless you're ready to get a real intake and cam.
If you build a stroker and select a good cam along with the heads and a good shorter-runner intake, you can start making real power: well over 400rwhp are easy to get, depending on how radical you're willing to go with the street manners. 99% of people here have no idea how fast a C4 with an honest 400-450rwhp really is. It's fun. If you insist on a FIRST intake, you can count on being limited to about 350-375rwhp with all the same other equipment and same street manners (mostly a function of the cam). At this point, you're talking about spending $6-7k for this build, so IMO you should be aiming for at least 400rwhp.
ETA: I don't know what ECM you have, but you need to make sure you have a way to tune it for your stage 3 level of mods. You probably don't need to do that for stage 1. Your stage 2 proposal...I don't know: with a stock cam and a long-runner intake (FIRST), it might not even need a tune...which is also an indication of how little power it will add.
I specified that I would not upgrade the heads without also upgrading the intake to the FIRST. Both are part of "Stage 2".
"I don't know why anyone would spend the ~$3000+ to get AFR heads and a fancy new intake and then choke it with 24" runners and the stock cam"
That doesn't quite make sense to me. How would I utilize the fancy new intake (FIRST TPI) and simultaneously choke things with the 24" (presumably 19" stock TPI" runners), when I am utilizing the fancy new intake?
Regarding upgrading the heads and intake (by this I meaner intake manifold, runners, and plenum), but NOT the cam, this is a matter of cost/time/benefit. Pulling the shortblock to swap cams, I might as well go stroker at that point, which is why stage 3 includes BOTH cam and stroking.
ALSO there are a lot of people with 383s, FIRST TPI setups making well over 350-375hp. Additionally, peak HP is not my only goal here.
Thanks for the input.
Later I switched to the TPIS MiniRam, and lost ~18hp, I think?
I agree with you about the manifolds; not as bad as 3rd gen F-bodies....
but not great either. The cross sectional area of each primary at the collector is tiny.
