1993 speedometer on crack
Old Jan 4, 2022 | 09:26 PM
ericunderwood's Avatar
ericunderwood
3rd Gear
Default 1993 speedometer on crack
After about 20 minutes of driving the speedometer will start reading random numbers that vary around 20 or 30 mph below and above what I am currently driving. I checked the plastic gears and they are in good condition. This also messes up my cruise control and the radio VSC. I read that it could be a connection somewhere or it could be the speed sensor which is hard to find. Where would be any connections in the wires to check? Any other ideas? Car has an automatic transmission.
Old Jan 4, 2022 | 10:33 PM
pedricd's Avatar
pedricd
Is anything else happening? Any other lights (such as service ASR)? SYS showing on LCD? Security light blinking while running?
Old Jan 5, 2022 | 11:27 AM
ericunderwood
3rd Gear
No, I have no warning or trouble lights on. LCD always works, just reads incorrect speed.
Old Jan 5, 2022 | 11:43 AM
WVZR-1's Avatar
WVZR-1
What rear axle ratio? That would have much to do with the availability of the VSS.
The connector at the VSS is very common and an easy replace. If your car is a C68, what does that display for MPH? Cruise, VSC and display are all 'after' the ECM! Cut/splice or connector and do your own terminations might be a reasonable next move.
Old Jan 5, 2022 | 03:53 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I had a similar problem with my 90, the speedometer would start jumping all over the place, it turned out to be the wire running from the ecm through the firewall to the connector under the passenger side dash, I ended up running a new wire from the ecm and bypassing the connector. That fixed the problem.
To 1993 speedometer on crack
