Suspension Upgrade Opinions
DRM trailing arm brackets vs after dark speed?
https://www.ebay.com/itm/30324971006...wAAOSw1YNgHH0r
-Solid Batwing Diff mounts?
-Strut Rod Camber Kits; After Dark vs Van Steek
https://www.ebay.com/itm/30367276971...kAAOSwCWRgHHpr
https://www.vansteel.com/index.cfm?f...p=1906&ID=2387
-Adjustable Bump Steer After Dark vs Vansteel
https://www.vansteel.com/index.cfm?f...p=1906&ID=2624
In the rear camber rods and trailing arms it's useful to have spherical rod ends precisely because you shouldn't use poly back there, and because stock rubber is no longer available. So don't use those Van Steel links - those are terrible. The SuperPro soft poly bushings are the only good alternative to sphericals. I'm sure the After Dark links are fine, and again if you don't know what the height adjustments do and how to test them, then that's a feature without a benefit. The later C4 geometry like yours is pretty good from the factory. Another brand to consider is Banski. They've been around a very long time and have tons of good info on their site (including the CAD drawings), and Tom Urban is super helpful with tech assistance if you need it. Spherical-ended, threaded camber rods are more important for the camber rods than the trailing arms because they eliminate the factory eccentric camber adjuster that is prone to slippage. Even if you keep the stock trailing arms or use Super Pro bushings in them, I recommend the rod-ended camber rods.
