Contemplating 1.6 RR's
Old Dec 28, 2002 | 01:39 AM
spdrcrj's Avatar
spdrcrj
Default Contemplating 1.6 RR's
Im contemplating putting 1.6 RR's in my car. What can I expect from this mod, which ones should I get, how hard is it to do, and can I do this mod alone or do I have to do change anything else? I dont know much about this mod and am looking for some good info.
Thanks all,
Jim
:flag
Old Dec 28, 2002 | 01:58 AM
superlund's Avatar
superlund
Default Re: Contemplating 1.6 RR's (spdrcrj)
With the compostie valve covers you will most likely need to remove the drip rails/webbing on the inside of the covers, unless someone here can steer you toward a brand that will clear...the Comp Cams Pro Magnum's won't clear...
:seeya
Old Dec 28, 2002 | 02:07 AM
weracemo's Avatar
weracemo
Take a look at this thread
http://forums.corvetteforum.com/zerothread?id=456809
hope it helps..... :thumbs:
Old Dec 28, 2002 | 09:46 AM
vader86's Avatar
vader86
Standard gain is roughly 15hp, other than maybe the inside of the valve covers, you dont have to change anything else.
Crane, Comp Cams Pro Magnum are both good.
Old Dec 28, 2002 | 11:09 AM
Corvette0096's Avatar
Corvette0096
Default Re: Contemplating 1.6 RR's (vader86)
:iagree:
To Contemplating 1.6 RR's
