Fuel Course
Old Jan 23, 2022 | 04:44 PM
Charles212's Avatar
Charles212
Default Fuel Course
Good Afternoon, I am confused and seeing contrasting information.
on 1985 C4, Does fuel flow from the tank first to the FPR and then the rails or does fuel flow to the rail and then the FPR. I am not understanding the direction of flow.
And: is the fuel filter on the rail part of the return line or the fill line??
Thank you.
C
Old Jan 23, 2022 | 06:21 PM
JD1964's Avatar
JD1964
The pump sends fuel to the rail first. The regulator has a spring loaded valve. The excess pressure that the pump develops overpowers the spring in the regulator. The pressure bleeds through the regulator valve sending fuel back to the tank.
Old Jan 23, 2022 | 06:50 PM
Charles212's Avatar
Charles212
So is the fuel filter then on the fill line or the return line back to the tank. I have seen it noted that it is part of the return. I had made the assumption that it was on the Fill. Which is true?
Old Jan 23, 2022 | 07:27 PM
ajp01's Avatar
ajp01
It is always on the Fill. The post you are referring to mentions another (second) filter on the return line on some cars only. On the TPI cars, the rails and the injectors get the fuel first, then the excess goes out of that gray pipe that exits the fuel pressure regulator (bolted on top of the rail). That is the return line.
To Fuel Course
