C4 exhaust
https://www.corvettecentral.com/c4-8...f%3fcount%3d54
Would that hang right from an 1989 with long tube headers mated correctly?
It looks like I would need the later 92-96 hangers. Any links to these parts?
Also what is the difference between that sort of "chambered" pipe vs this "straight" pipe:
https://www.corvettecentral.com/c4-8...f%3fcount%3d27
How much of a difference are the 2 3/4" pipes going to make vs the 2 1/4" pipes of this setup:
https://www.corvettecentral.com/c4-8...f%3fcount%3d72
Goal is eventually a 450 hp 383 so...
As far as straight vs chambered, the chambered has small crimps that act as baffling inside the tubing. (Iirc they are both sold and that's exactly what it is through the vendors... you can use that with eliminators for a chambered eliminators)
For 450hp you'd really be pushing it with 2.25 but it could be done. No penalties with a larger exhaust in that size...
How much power do you think the factory 2.75" GM LT1 catback system can support? How much power might a nice L98 TPI build (long tubes, heads, cam) be leaving on the table with the factory GM LT1 catback vs a true dual system with muffler and center resonator eliminated. Similarly how much power might a Borla LT1 catback system be leaving on the table as compared to a true dual eliminator setup with no mufflers nor center resonator?
Might a 2.25" eliminated setup with no center resonator nor mufflers flow similarly to a 2.5" or 2.75" Borla LT1 Catback or factory GM LT1 catback, both having center resonator and mufflers?
Thanks!
I am trying to balance cost, noise, ease of install, with flow and power capability...
Thanks!
You aren't leaving anything on the table (or much for that matter) with an LT system. A stock LT1 system will more than meet your needs.
Again the LT-1 setup is really good, you would be hard pressed to make up the difference in a 2.25 just having it open. And with a 2.5 if you so choose you will have room to grow again. Because we all know the first goal is never enough lol.
I told him he needs to get "new hangers" to hang the LT1 exhaust from his 1985 4+3, but I am not sure exactly what parts he needs. Any pointers?
Similarly I am planning on probably getting a 92-96 catback system to put on my 1989 with the ZF6. I am trying to figure out what hangers I need to do this...
There is a Borla catback set for sale on the forum marketplace right now that I am considering. I am worried though that it will be leaving power on the table as compared to a muffler eliminator setup that also has no center resonator, kind of like one of the kits from corvette central.
The rear hangers that bolt to the diff are a little hard to come by, the good news is, the C5 and C6 corvette use identical hangers.
Looks like Corvette Central has caught on to this fact https://www.corvettecentral.com/3240...YaAktbEALw_wcB
