Loose column
Old Jan 26, 2022 | 07:33 PM
Bribr's Avatar
Bribr
Default Loose column
Steering column is very loose on my 86
how to fix ?
Old Jan 26, 2022 | 10:18 PM
CorvetteRules's Avatar
CorvetteRules
Are you talking about just the steering wheel or the column itself????
Old Jan 26, 2022 | 10:20 PM
Arg0413's Avatar
Arg0413
I had just had bad wobble in the column in my 1990. Marc Haibeck sells an oversized column in for $50, and it takes 30 min to install. Greatly improved it for me.
Old Jan 26, 2022 | 11:54 PM
Bribr's Avatar
Bribr
the column moves quite a bit it was just wobbleing a little then it made a bang noise and got way worse
Old Jan 27, 2022 | 07:07 AM
CorvetteRules
Did you remove the knee pad and metal panel under it to check the two bolts that hold the column ?
Old Jan 27, 2022 | 12:06 PM
84 4+3's Avatar
84 4+3
If you grab the wheel and move it in a circle, does it just flop all around or does it kind of feel like it moves in a square manner?
Old Jan 27, 2022 | 04:46 PM
mike1111's Avatar
mike1111
could be the 4 bolts that come loose on gm columns. there's videos online.
Old Jan 27, 2022 | 04:52 PM
WVZR-1's Avatar
WVZR-1
It 'could' but all '86 columns don't use that 'lock plate'. All 'verts have the later column and I understand that later coupes don't either. The 'verts being different is pretty well documented using GM SPO info but coupes it requires a 'look see'!
It would be the first inspection I believe. Buy the plastic wear parts in the upper housing and do that maintenance while looking deeper and securing the bolts to the lock plate you mentioned.
Old Jan 29, 2022 | 04:59 AM
rhandle's Avatar
rhandle
This happens on all C4s so be careful. If you use the steering wheel to pull yourself out of the car,you stretch the soft aluminum components in the column and destroy them. DON'TOUCH THE WHEEL. Use the A pillar instead to pull your self out
Old Jan 30, 2022 | 03:18 AM
Bribr's Avatar
Bribr
I’m well aware of that & never use wheel to pull myself out of car but just turning the wheel with car of is was happened
To Loose column
