Motor mounts
Old Jan 29, 2022 | 08:31 PM
johnfin's Avatar
johnfin
Default Motor mounts
What is the best way to remove mounts. I need to lift engine. Long bolts are tight even when i lift engine. 3 bolts on block are hard to get at.
Old Jan 29, 2022 | 11:12 PM
FostersPerformance's Avatar
FostersPerformance
Take nuts off bolts. Dont try to spin the bolt.....once nuts are off lift engine a little and 'work' the bolts out. Old mounts are probably binding the bolts up....a PITA but they will come out.........the 3 mounts to block bolts are close to impossible to get out, and more of a pain to get back in...once you do this replace the mounts and bolts.
good luck!
Old Jan 31, 2022 | 08:01 AM
blackozvet's Avatar
blackozvet
if trying to get the C4 engine mounts out with engine still in situ, first go to the Doctors. Get a sedative, valium is the best choice for this particular task.
Old Jan 31, 2022 | 08:47 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Why don't you spin the bolt. That's one way that I've done it for decades...(?) Works good.
Old Jan 31, 2022 | 09:05 AM
FostersPerformance
Only say that because when i tore mine down, the rubber in the mounts was keeping the bolts from spinning. Dont remember if they swelled up or were broken, but had to take nuts off and use a mallet while working the bolt to get it out.
Old Jan 31, 2022 | 11:24 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Copy. That makes sense. In MOST cases, though, the fastest, easiest way is to hold the nut w/a wrench, spin the bolt, and after the nut is off, keep on spinnin' the bolt and it'll thread right on out of the mount and back all the way out. Assuming you have the space to allow for that to happen, of course.
Old Jan 31, 2022 | 01:21 PM
383vett's Avatar
383vett
That works for me. The 3 bolts on the block I remove with the engine in place using an offset 9/16" box end wrench. This can be done with the long bolt in place and the motor sitting on the mount.
383vett's Avatar
383vett
To Motor mounts
