The case for overlap (and LSA).
Old Feb 10, 2022 | 01:38 PM
wilcar's Avatar
wilcar
Originally Posted by Phobos84
There is a great thread that is now a sticky over on LS1Tech forums. You can see it here.
It does a great job explaining what LSA is and isn't. It also goes into overlap. What I gather from that write up and others are that LSA and overlap alone in STREET CARS won't change top end significantly but will drastically change drive-ability and tune-ability. So if it's a street application and you want to be able to idle at a stop sign and you want it to be easy to tune then you need a cam that will give up power everywhere. Just like increasing lift and duration can increase power so can changing the LSA but all of these dimensions can and will effect "drive-ability". The thing is that concept is subjective to the individual.
I could care less if the motor has chop. Also I don't care if I leave 5 to 10 hp on the table so to speak. My criteria in a camshaft is low cost, and easy tuning with a cam that can meet my power goals. This is why I always go with an off the shelf cam that was designed for factory length push rods. I totally avoid the custom or re-ground cams.
Companies like Elgin and Summit Racing have done an amazing job making good low cost performance cams that are easy to tune. But again this is for a street car. If this is a racing application then it is a totally different scenario and far outside of my wheel house.
Some of the old California cam makers like Crower, Isky, and Clay Smith still have quality cams and decent prices. Have used them all and never had a problem. Currently using 2 Isky solid lifter cams, one in my 84 C4 and another in my 65 Gto. Old school grinds that are easy on the valvetrain. Both cams ground on 108 LSA .
Old Feb 11, 2022 | 10:42 AM
stingr69's Avatar
stingr69
Are you still running that Isky Z-20 on 108 LSA? How does it idle? where does the power band start and drop off? I was thinking about swapping that into my 10:1 302 engine.
Old Feb 12, 2022 | 08:18 AM
wilcar's Avatar
wilcar
Still running the Z20. I have 14-15 " of vacuum at 900 rpm. Have a mild stall convertor in the 700r4 and 3.07 gear. I think it would work fine in a 302. The Z20 is not to far off from the 097 cam specs . I have plenty of power up to 5000 rpm and could go higher. With the 700r4 I have a lot of low and mid range. I run the same spec Isky cam in my 470" 65 4 speed Gto and it pulls 18" of vacuum ! Note: Z20 has 112 LSA but I ordered mine direct from Isky with the 108 LSA .
