1985 c4
Old Feb 2, 2022 | 08:29 AM
Theo101's Avatar
Theo101
1st Gear
Default 1985 c4
What pounds are the fuel injectors for a 1985 c4? Is it 22lbs or 24lbs? And what would be the best injectors to get? OEM or something else?
Old Feb 2, 2022 | 07:35 PM
Phobos84's Avatar
Phobos84
This is kind of a tough question to answer without more info. Why are you replacing your injectors? Are they leaking? Are they tapping? Are you upgrading the motor for more power and you need more fuel? If your injectors are worn out you can send them off for a rebuild service that doesn't cost that much and they will come back like new.
Old Feb 2, 2022 | 10:24 PM
jdjenk's Avatar
jdjenk
The stock ones are 24 lbs on the 85.
Old Feb 2, 2022 | 11:00 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
24, and call john bannerman at fuel injector connection
To 1985 c4
