85 corvette what coolant do I use?
Old Feb 10, 2022 | 03:52 PM
JackCorvette85's Avatar
JackCorvette85
Default 85 corvette what coolant do I use?
Anyone let me know send a picture of the bottle that will help!
Old Feb 10, 2022 | 08:56 PM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
It came with good old fashion Green antifreeze. Fill with 50/50 mix of antifreeze and distilled water or you can buy premixed. But you can make 4 gallons of your own for about $8 more than 2 gallons of the premixed stuff👍
Old Feb 11, 2022 | 03:12 AM
topfuel67's Avatar
topfuel67
Make sure there isn't orange coolant in there. If there is make sure to really flush it out. Green doesn't mix well with the new stuff and a lot of times people put the dexcool since the modern ones now use it.
Old Feb 11, 2022 | 05:29 AM
LiveWire1's Avatar
LiveWire1
There's no need for Dexcool, because in 85, the engines were all iron with no aluminum heads. Just go with the green old faithful.
Old Feb 11, 2022 | 08:46 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Napa sells true green coolant..
Zerex Original Green Concentrate Antifreeze - 1 gal
Old Feb 11, 2022 | 03:25 PM
Kilobuck84's Avatar
Kilobuck84
Nothing wrong with green except you have to change it more often than Dexcool, or other extended life antifreeze. Dex will not hurt your cooling system as long as you get all the old coolant thoroughly flushed out. But no matter what you use you should get all the old coolant thoroughly flushed out.
Old Feb 11, 2022 | 03:48 PM
vader86's Avatar
vader86
I use regular old green Prestone. Drain and refill about every 2-3 years.
To 85 corvette what coolant do I use?
