Early 4+3 shift knob button
Old Feb 13, 2022 | 05:54 PM
johnfin's Avatar
johnfin
Default Early 4+3 shift **** button
On the 84 and 85 does the shift button depress to allow it to go into reverse?
Old Feb 13, 2022 | 07:57 PM
s carter's Avatar
s carter
It's just a Overdrive On/Off Switch.
. There should be a collar under shifter **** that is lifted to clear the path to reverse gate in shifter
Old Feb 13, 2022 | 08:20 PM
84 4+3's Avatar
84 4+3
84 and 85 should use a lift ring.
Old Feb 13, 2022 | 09:15 PM
johnfin's Avatar
johnfin
overdrive switch is on the console for an 85, not the stick
To Early 4+3 shift knob button
