main fan running
Old Feb 14, 2022 | 09:46 AM
kenmohr's Avatar
kenmohr
Default main fan running
Should the main radiator fan turn on when starting a cold engine? 89 vette Turns off when vette gets to 180*s
Old Feb 14, 2022 | 11:40 AM
7thvet's Avatar
7thvet
I would say no, but the auxiliary fan might if a/c or defroster is on.
Old Feb 14, 2022 | 01:49 PM
kenmohr's Avatar
kenmohr
This is the fan on the engine side of the radiator. It is the one the AC turns on automatically. Thanks for the input. Everything else is turned off.
Old Feb 14, 2022 | 01:53 PM
vader86's Avatar
vader86
If the AC is on, yes it could. Otherwise it shouldn't until it hits a preset Coolant temp. That could be 228 F factory, but if someone changed it, or wired it to ground or a switch, then it would.
Old Feb 14, 2022 | 03:23 PM
LiveWire1's Avatar
LiveWire1
Check the wiring of the fan relay. You may have the fan wire on the normally closed contact instead of normally open.
Old Feb 15, 2022 | 04:40 AM
kenmohr's Avatar
kenmohr
There are no mods. Worked properly when I put it up for the winter. Went to do some work cleaning it up and the fan turned on as soon as I started it. Had a pressure switch go bad before wonder if I'm going down that road again.
To main fan running
