Automatic lowered rear end
Old Dec 29, 2002 | 09:58 AM
swoosh's Avatar
swoosh
Default Automatic lowered rear end
Some how the back of end of my vette dropped 1-2 inches??? I can see the difference in how the wheels well sits so close the back tire, as the front wheel well sits higher from the front wheels. My vette is a stock 96. Is there some secret button that i pushed to lower the back end. I think it looks better lowered. I would just like to know what happened?? Did i hit too many bumps in the road? :crazy: :confused:
Old Dec 29, 2002 | 10:00 AM
swoosh's Avatar
swoosh
Default Re: Automatic lowered rear end (swoosh)
:iagree: if you look at the old picture you can see the back end sits higher than the front. NOW the back end has dropped substantially :skep:
Old Dec 29, 2002 | 10:23 AM
Rich B.'s Avatar
Rich B.
Both pictures look the same to me...Car doesn't look like it even moved... :rolleyes:
Old Dec 29, 2002 | 10:24 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Same thing happened with my 95 vert 2 years ago.
upon close inspection, we found that the rear sring was broken. It was actually splintered.
to check, put your car on a lift and use a flashlight. I you still dont see anything, use a rag and "wipe" across the spring in each direction to see if it snags on any "splinters".
wear HEAVY gloves while doing this.
the only other thing I can think of, would be that your shocks have bit the dust.
Old Dec 29, 2002 | 10:26 AM
Phil-tha-Rush
Default Re: Automatic lowered rear end (Rich B.)
:D :iagree:
even same time of day :D
Old Dec 29, 2002 | 10:50 AM
JCAIRE2's Avatar
JCAIRE2
Default Re: Automatic lowered rear end (Phil-tha-Rush)
:iagree: I think Phil beat me too it. Check spring, at least the rear is easy to replace. :steering: :steering: :steering:
Old Dec 29, 2002 | 11:15 AM
swoosh's Avatar
swoosh
Default Re: Automatic lowered rear end (JCAIRE2)
Thanks. I checked it out...the LEAF SPRING is $%#%^@ like you said!! splintered is an understatement !! :iagree:
Old Dec 29, 2002 | 11:52 AM
Phil-tha-Rush
im IMPRESSED!
I have only 4000+ posts and FINALLY was able to help someone :cheers:
:D :D :D :D :D :D :D :D
Old Dec 29, 2002 | 10:08 PM
VetteRacer282's Avatar
VetteRacer282
swoosh: I have a spare 39.9n/mm (I think, will have to double check its rate) spring (heavy duty spring in 96, its off an 86 and was considered base spring then). Its in good shape, used it on my car when mine broke, it was off an 86 that was converted to SCCA race car, and was on my car for ~20k miles.
Let me know if interested.
Matt
Old Dec 29, 2002 | 10:09 PM
VetteRacer282
Default Re: Automatic lowered rear end (VetteRacer282)
P.S. I also have a rear end lowering bolt kit I will sell with the spring so you can lower it to how you like the look...
Matt
Old Jan 1, 2003 | 02:57 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
:confused: :confused: :confused: Sorry but I can't see the difference????
:confused:
Old Jan 1, 2003 | 10:49 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
im IMPRESSED!
:lol:
To Automatic lowered rear end
