Newbie nitrous question
Old Dec 29, 2002 | 11:56 AM
ludachriss2's Avatar
ludachriss2
Default Newbie nitrous question
I don't know if this topic has been beat to death or not, (I just joined the forum and I can't seem to locate a search method) So here goes... Are there any big benifits to running direct port instead of a plate setup? I am only planning on running a 125-150 shot. Thanks in advance for any advice :crazy:
Old Dec 29, 2002 | 05:58 PM
scorp508's Avatar
scorp508
2 main things I see to direct port are....
1. You are nearly sured to get the same N/F ratio in each cylinder.
2. You won't have nitrous puddling in your intake manifold.
Old Dec 29, 2002 | 06:43 PM
Phobos84's Avatar
Phobos84
Default Re: (scorp508)
Start with a plate system and then if you want to sell it and move to direct port. Start small and work your way up. Direct port is very expensive and takes a lot of work.
To Newbie nitrous question
