Engine Build Planning Question
Old Mar 10, 2022 | 12:04 PM
SpitfireC4's Avatar
SpitfireC4
Cruising
Default Engine Build Planning Question
Hello all,
I have an '85 that I picked up recently. I'm in planning stage of building up the existing 350. I've only bought these headers so far.
Does anyone know which type of head I need so that there is enough clearance for the plugs (i.e. should I be getting the slanted outlets for the spark plugs or will there be enough clearance for the ones that come out straight?).
Appreciate any insight.
Old Mar 10, 2022 | 12:29 PM
vader86's Avatar
vader86
It will fit the L98 angled plug heads, should fit the straight plug head too. The angling should be listed on any head description for a head you intend to buy from Jegs/Summit etc. The difference is how much a PITA it is to get to a couple plugs.
So what is the head you are wanting? it would be easier to answer that way.
Old Mar 10, 2022 | 12:33 PM
SpitfireC4's Avatar
SpitfireC4
Cruising
Thanks for the Reply.
I'm thinking these heads (which are straight plugs).
Do you have a recommendation as to if I should find an equivalent angled head or run with these?
Old Mar 10, 2022 | 12:42 PM
vader86's Avatar
vader86
I would generally go for the angled plug head, yes.
I don't know ProMaxx flow numbers but I'd research more of that data vs price. Most of us here, including myself, push AFR 190s, but they are not cheap heads.
Old Mar 10, 2022 | 01:00 PM
SpitfireC4's Avatar
SpitfireC4
Cruising
Thanks for the info. I'll look into the AFRs as well!
Old Mar 10, 2022 | 06:57 PM
84 4+3's Avatar
84 4+3
The jegs brand 195 cc heads (profiler) are also an option. But the exhaust port is raised which can potentially cause a plug clearance issue. It's a lot of head for the money. Not quite an AFR but you need to value what you want vs what you're willing to spend.
Old Mar 16, 2022 | 02:39 PM
SpitfireC4's Avatar
SpitfireC4
Cruising
Hey Vader,
I have one more question if you do not mind.
I'm looking at these valve covers, do you know if there will be enough clearance for the wiper motor?
Thanks,
Old Mar 16, 2022 | 02:53 PM
vader86's Avatar
vader86
I don't have the PN for the AFR covers i'm using but they aren't tall style covers, the tall height does not work, so I can't tell you for sure, but I doubt those will clear the wiper motor. You'd have to use stock height.
Old Mar 16, 2022 | 04:36 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If you do, Vader meant their 195's. Or...even their 180's -- depending on your needs. You can get better flow using a smaller cam with the 195's. The headers you bought aren't a match for the 195's though. (no idea on the 180s) 195 exhaust ports are bigger than those Hedman header inlets [you bought]. You should pick the heads THEN the headers that will fit.
To Engine Build Planning Question
